newer motor with older clutch
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CBLAZER81, Aug 31, 2002.
  1. CBLAZER81
    CBLAZER81 1/2 ton status
    Mar 3, 2000
    281
    Milliken,COLORADO
    the motor blew in the 81 blazer and I'm having a helluva time finding a good block. Picked up a '90 350cid today and realized the bolt pattern on the crank,for the flywheel,is different.
    My ? is, will the bolt pattern on the old clutch match up with the newer style flywheel? I don't wanna have to buy a new clutch.
  2. CBLAZER81
    Mar 3, 2000
    281
    Milliken,COLORADO
    Anybody? I need help on this one.
  3. dyeager535
    26,982
    191
    Are you saying you HAVE the one piece (rear main, newer block of course) flywheel and are curious about the pressure plate/clutch, or are you wondering if you need a flywheel for the newer motor?
    I can't say for sure on the clutch/pressure plate (although I'd imagine the bolt pattern on the flywheel stayed the same) but you will need a different flywheel, I'm 99% sure.
    If the flywheels interchange from like '59-86, (approx, IIRC, one piece came of being in 1986) and '86-up, then you'll need a new one.
  4. CBLAZER81
    Mar 3, 2000
    281
    Milliken,COLORADO
    Yes,I HAVE the newer block with the one piece rear main seal. (builder block)
    The old one is the older style,2 piece rear main. (blown up,still in truck)
    I found out this morning that they used the same clutch from (approx) 1978-1994. So my old clutch SHOULD bolt up to the newer style flywheel.
    Thanks for the answer though.
  5. loudnowlouder
    loudnowlouder 1/2 ton status
    Jan 29, 2001
    539
    Ellicott City, MD
    yes it will fit
    i had an 85 305 with the 2 piece rear..
    swapped in a crate engine with the one piece, got a new flywheel and the old clutch fit fine...the main bolt pattern is the only real difference in the flywheels, still the same diameter and # of teeth...no reason for them to make a new pressure plate pattern as well....
    just make sure you check the clutch out real good, it's easiest to swap in a new one now, but if this one is fine and money is an issue, bolt on what you have
