Newer rims on 90 Blazer
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Hardcore, Apr 25, 2003.
  1. Hardcore
    Hardcore 1/2 ton status
    Apr 25, 2003
    458
    New Orleans, LA
    Woohoo, my first post on CK5.
    Been reading this board for a long time, figured it was time to join.
    My question is: I've got a buddy with 15x8" Eagle 589's off of a Z71. Will they fit on a 90 Blazer. I know the bolt pattern is the same but will they fit over the hub. I checked Eagle's website and they only offer 1 589 in 15x8 so I figure it's universal. /forums/images/graemlins/confused.gif
    Thanks in Advance
  2. sdavid
    sdavid 1/2 ton status
    Aug 5, 2002
    244
    Livingston, TX
    I think you're right. Especially since it is a 15 inch rim. Make sure the offset is something around your stock offset and you should be good to go.
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    test fit them
  4. Hardcore
    Apr 25, 2003
    458
    New Orleans, LA
    Steve,
    I'd like to but I'm still in the process of getting the 90 K5. I was hoping to snatch up these rims before he sold them to someone else. I see you have 10" 589's, I guess if they fit fine then the 8" wouldn't have a problem. /forums/images/graemlins/rolleyes.gif
  5. bigjbear
    Feb 18, 2000
    13,964
    446
    Marietta GA
    Measure the backspacing before laying out $$$, but they should fit
  6. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    If the backspacing was correct for the IFS truck (5.5"), it will not be correct for your truck (3.5").
  7. Hardcore
    Apr 25, 2003
    458
    New Orleans, LA
    Eagle lists the 15 x 8 as a 3.25" backspacing. That should work then.
    What diameter is the hub on a 10 bolt? 3"???
