Newest MOD to "UAV"
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CK5, Aug 28, 2000.
  1. CK5
    May 19, 1999
    21,623
    701
    CO
    Newest MOD to \"UAV\"
    After the ORD flip review, I will be doing the Hill 4 Wheel Drive 2" longer (1" lift) than stock front shackle, I installed them on Sunday and these things are massive, they also give plenty of room for spring compression and feature a center tube for strength, they drilled the 7/16" holes out to 1/2" so I could use ORD's bushings. I used a 4 degree shim and have no vibration. My Blazer sits level now with 5" in front and ORD flip in the back without the top.
    5,000 Pounds of American Rolling Steel
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Re: Newest MOD to \"UAV\"
    Those are cool[​IMG]!
    Does Hill 4 Wheel Drive have a website?
    [​IMG] Sept 1
  3. CK5
    May 19, 1999
    21,623
    701
    CO
  4. getsome
    getsome 1/2 ton status
    107
    Colorado
    The lower bolt looks like it's realy close to the pipe. Is this a picture angle problem or is there more room then it looks?
    Getsome
  5. CK5
    May 19, 1999
    21,623
    701
    CO
    Must be the agle of the picture because there is plenty of room for the bolt.
  6. Donovan
    Donovan 1/2 ton status
    524
    Arvada, CO
    How does it drive now with the longer shackles or does it drive the same? How long are those things?
    Donovan
  7. CK5
    May 19, 1999
    21,623
    701
    CO
    I really haven't noticed any differance in ride quality and they are 2" longer than stock.
  8. CK5
    May 19, 1999
    21,623
    701
    CO
    I just went out and measured after the shackle install, the shackles raised the front by 1-5/8" and at the same time lowered the rear by 3/8". it looks like it sits level now.
  9. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Steve,
    Just wondering, did your truck not sit level after the flip. What I mean is, was your rear sitting higher or something? At first, I thought mine was, but now when I look at it, I think it sits level. So with those new front shackle, I think mine will have the saggy butt syndrome. Am I right?
    Boss
  10. CK5
    May 19, 1999
    21,623
    701
    CO
    Keep in mind that I have my 300# plus hard top off and the ORD shackle flip raised the back another 1/4". I think it sits pretty level, maybe a tad higher in front but not noticeable. If you took off your hard top you would be fine otherwisw, saggy butt time.
