newr and older axle fit
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dammit32, Aug 9, 2002.
  1. dammit32
    dammit32 1/2 ton status
    Jul 20, 2002
    365
    Maine
    does anyone know if a semi-float 14 bolt from an 88-2500 3/4 ton truck will fit my 91 k5 blazer ....i cant seem to locate a full float 14 bolt but can get a deal on a semi float but not sure if it will fit cause the truck has the new body style /forums/images/icons/confused.gif
  2. djohnsn
    djohnsn 1/2 ton status
    327
    Plano, Texas
    I have a 14-bolt sf out of a 93 light duty 3/4 ton that I was planning to use in my 78 Blazer. The spring pads and shock mounts have to be relocated. The width (wms to wms) is greater than the Blazer rear, but almost the same as the front.
