NJ drivers
Discussion in 'The Lounge' started by '89 bucket, May 18, 2005.
  1. '89 bucket
    '89 bucket Registered Member
    Feb 22, 2005
    25
    delanco N.J.
    ok, all you New Jersey drivers,,,,
    i just got a $180.00 ticket because i don't have a second inspection sticker for stability??
    had no idea i needed one,,,,
    anyone have any idea what i need to do for this or any way around it
    i have a 4" lift with 35 x 12.5's
    what is entailed on the stability test?
    PLEASE HELP!!
  2. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Whaaaa...??
    Is this something documented when you registered the vehicle? If so, you might be screwed, if not, you might be able to get it tossed, but don't bet on it.
  3. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Alright, this settles it.
    (mental note) never move to east coast
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    note: Just Jersey buddy, I really just hate that state :D
    Pretty certain they just have you drive through some cones to prove stability. Yunit would know better than I.
  5. Ruthven13
    Ruthven13 1/2 ton status
    Mar 10, 2003
    664
    Fair Verona
    There are a few special inspection places for that, though I am not sure where they are. They check for mud flaps, tire coverage, and stability. I have never gotten it done and never gotten the ticket though. Nor anybody else I know. What town did this happen in? Only time I ever got hasseled about it was in Maine, but since the truck isn't regestered there he couldn't do anything.
  6. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Yankees for ya :D
  7. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    I disagree, MN doesn't have any way shape or form of vehicle inspections.
    I think it's more like east coast latte sipping liberals for ya. :p:
  8. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    its no big deal. i know they have one around me in asbury park. my buddy just went through it. they measure from the ground to bottom of the rocker panels and do a couple of other dumb tests, give you some paperwork and a sticker and your on your way.
  9. mikayak390
    mikayak390 Registered Member
    Mar 3, 2005
    70
    NJ
    I live in NJ and have for years. (Not defending the state) however I only have one inspection sticker. Just drove the 89 suburban through with no problems 2 months ago.
    NJ sucks for emmisions, but never heard of stability? They do stick the truck on a dyno and then on a suspension tester.Basically a plate that vibrates back and forth to test worn bushings, bearings, that sort of thing as well as brake pressure front and rear when stopping.
    Other than the first guy driving onto the dyno at an angle and telling me there is a transmission problem because the truck is "bucking " at high RPM. I watched the right rear spin on the drum while the left rear tried to catch the corner of the drum and the concrete floor at the same time. Supprise supprise the left wheel would make the truck buck forward when it caught the concrete instead of the drum roller. I argued the point but had to drive around the block and go back to another tester who was smart enough to drive straight onto the dyno with both wheels spinning smoothly on the drums. For some reason the truck did not "buck" any more.
    Other than that I am good for another two years. woo whoo
  10. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    yes nj sucks most of us in nj trailer to the trails but 4" and 35s -- sounds like he is an a$$ i think this is still in date link http://members.aol.com/snowman629/truck/liftlaws.htm
    and i think you can only can have 32" from the bottem of the door to the ground also some thing like that
  11. '89 bucket
    Feb 22, 2005
    25
    delanco N.J.
    i read in one of the other posts, the lift laws from the nj dot.
    the first sentence states that any vehicle "over 4 inches from stock" needs all this extra "attention"
    i installed a 4" lift, it's not "over" 4 inches so should i be ok?? :confused:
  12. '89 bucket
    Feb 22, 2005
    25
    delanco N.J.
    this was really helpfull
    thanks
  13. ramjet gmc
    Dec 19, 2001
    3,370
    yes it is this is why you have larger tires stock 31 you 35 1/2 of 4" is 2'' taller add the 4'' lift now it is 6in this is what the cops say and the insption station say - good luck
  14. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    I sense someone has a guilty conscience. :D
    I've never considered anyone from MN a Yankee. You guys come across as more Canadian than anything :D
  15. '89 bucket
    Feb 22, 2005
    25
    delanco N.J.
    ok, i just talked to one of the shops that does this stability test and they say that you need this done if you lift your truck 4" or more
    whatever raises your truck 4" over stock
    who can tell me what the original stock height of the '89 k5 is?????
  16. ramjet gmc
    Dec 19, 2001
    3,370
