No accessory position???
Discussion in 'The Garage' started by TruckNutzDude, Aug 8, 2003.
  1. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    Do all ignition's have an accessory position or do I have one of those rare ones where you have to run the truck to listen to the tunes? I have a '90 K5 with tilt and the "silverado" package. I can't turn the key backwards at all to where the acc. position should be. What gives? /forums/images/graemlins/thinking.gif
  2. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    Could be a bad iggy switch or a worn key cylinder. I'm fairly sure they all have an accessory position.
    I just replaced both on our 88XJ (GM tilt column), not expensive but it was a bit of a pain. Oddly enough it cured a multitude of electrical type problems we were having. I guess the iggy switch was so corroded inside it was not feeding the computer reliable power 100% of the time. The last straw was when it only had head lights and brake lights and would start. That was all it would do...
    The accessory position was also becoming more difficult to 'find' as it got progressively worse.
    Rene
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    My '90 Sub didn't have an accessory position when I bought it. A new $17 lock cylinder and 30 minutes of my time later and it was working great. /forums/images/graemlins/thumb.gif
  4. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    Sounds about right to me. I know how "hard" it is to replace the cylinder since I had to do one before on my '86 K10. It would start w/ no key! That's how bad it was. Anyways, while I'm in there should I adjust the lock for my tilt? It has a tendancy to self adjust while I'm wheeling. I know there are some posts up about it already, can someone give me a link to one since I haven't had good luck searching? Thanks guys... /forums/images/graemlins/thumb.gif
