no balls...(gears)
Discussion in 'The Garage' started by broncoman6524, Sep 13, 2006.
  1. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    so i have a stock tired out 350, coupled to a th400, which when my 700 needed to be rebuilt i let the tranny guy tell me to go to the 400 for strenght reasons...hes right but something about a 2.56 gear ratio in 1st pisses me off. I talked to my dad about it who basically made me get hte 400 and he told me to just live with it it moves and drives. HEs right there but idk im 16 and i hate not being able to spin the tires..even in mud:mad: lol. Soo i have 3.08 gears now with a 208 t-case. runnin 33s.
    Im about to put a set of axle off of a wrecked k5 in my truck that either have 3.73s or 4.10s we havent pulled the cover to check for sure. This will help me out drastically right?:confused: damn i feel retarted right now..ugh lol. if this aint gonna help me out what exactly should i do to gain more power? besides major things ie motor or tranny swap.
  2. k5floyd
    k5floyd 1/2 ton status
    Feb 6, 2004
    313
    Friendswood, Tx
    3.73 should help a bit but hopefully theyll have 4.10s which would prob be perfect for you app. other then that the first gear and the power loss going to th400 really are things you have to deal with. just use 4lo a lot more often when wheelin
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Going with deeper gears will definitly help with power. Going from 3.08 to the other axles should make a good bit of difference.
    Harley
  4. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    if you have manual lokcing hubs, keep them unlocked and put it in 4lo, since the hubs are unlocked, you will be in "2lo" and will have much better ratio, youll be able to spin the tires on the street. except after u gatta get out of lo so you dont fry the tcase. just some food for thought for ya :)
  5. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    3.73s will help some 4.10s will help alot. I just run low range in the mud also. My motor has never had enough power for the mud but in low it works really well
  6. tenderfoot1877
    tenderfoot1877 Registered Member
    Apr 10, 2005
    13
    San Antonio
    re: no balls (gears)
    the new axles will definatly help, 4:10's will be the best espesially with 33's
    not only that, but your speedometer will be right on if you go with 4:10's and you'll get better gas milage.
