NO BRAKE LIGHTS!!!!!!
Discussion in 'The Garage' started by darkshadow, Jun 3, 2004.
  1. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    I was told by a guy who almost hit me that i have no brake lights. Low and behold they dont work the bulb is new, but its getting no power???? wtf i'll look at it tomorrow after work where does the wire run to the back? i want to check it up front befor i go chaseing it through the truck. Any ideas?
  2. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,005
    838
    Pinckney, MI
    check your fuses, thats just a long shot. If need be you can pick up a wire short finder at like lowes or homedepot for like arround 40 bucks, theses things really do work, and they come in handy.
  3. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    I usually use an old 12 vdc warning buzzer to check for voltage. Quicker and normally eaiser then trying to read a meter or watch dor a light to come on especially when I all contorted up in a knot trying to get a ground and touch the positive post/wire.
    First thing I check is "Do the four way flashers work?"
    They use the same wires and bulbs of course. Not sure if they are on the same fuse but easy to check. Could be the brake switch or connectors if its not the fuse. A wiring diagram has the colors of the wires to look for. /forums/images/graemlins/smile.gif
  4. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    A lot of times it is the switch off the pedal that slips and needs to be re-adjusted or replaced if it is strpped /forums/images/graemlins/doah.gif
    Just start with the basics /forums/images/graemlins/thumb.gif
