No brake lights
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jimmyjack, Sep 10, 2000.
  1. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    All of a sudden my brake lights and turn signals are not working. I replaced the fuses and they both blew, even with the ignition off. I had to re replace the ignition lock today, I thought that was causing the problem but all the wires looked solid. Can anyone send a wiring diagram or a heads up as I have no access to a manual? Thanks a bunch. Gonna go start digging with a test light right now.
    creepin' and crawlin'
    Jim
  2. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    i hope this helps.....I had the same problem on an 81 suburban, the tailgate over the years from opening and closing caused the rubber over the wires to fray off and ground out the circuit. I would definately use a test light and try to follow every inch of the wires going back to the lights . I don't have a diagram for you though sorry.....good luck ......js
  3. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    Never thought of the tailgate, I'm going to check from the back to the front. Thanks for the help.I'll let you know
    Jim
  4. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    Hey JimmyDie6.2, I found it. It was my trailerlight hook up. It had rubbed on the frame for sooooo long it just attatched itself to the frame. All is well!
    Jim
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    Dang, you beat me to it, that is where I was going to tell you where to look.
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
  6. Bigmeats
    Bigmeats 1/2 ton status
    Jul 29, 2000
    523
    Manhattan IL
    Me too! same thig happend on my van
    Bigmeats
    Carl...75 Blazer...Manhattan IL
  7. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    I'm curious though, why did the turn signals bug out and burn the fuse? theyre on a different circuit right? a different fuse anyway.
    Jim
