No brake pedal travel and bad braking
Discussion in 'The Garage' started by sled_dog, Aug 25, 2003.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Alright took the K5 out tonight and well besides the fact that I desperately need a brand new carb(past done with these old used things), its a piece of junk. Nothing in my life ever goes my way I swear. I forgot that when you hit the brakes the pedal only travels an inch or so and it doesn't stop very well(compared to the newer vehicles I have at home), and the brakes never lock up on pavement no matter how much I try. After tonight I really really remember why I got my 95 but then I drove it and I hate driving that thing.
  2. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    I have just been dealing with brakes for the last week, I went through the whole system, first thing you should do it go get it pressure bleed at a shop, I was just told somw places charge about 35.00 /forums/images/graemlins/thumb.gif
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Really hard pedal and no power... sounds to me like maybe the booster has gone south. </font>
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I notice a difference when there is a vaccum line and when there isn't on the booster so i don't know. I forgot the booster vaccum line and it was insanely bad, even worse than it is normal driving.
  5. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> IT could still be a bad booster, they aren't neccessarily something that is either good or bad, it could still be kind of working but not to it's full potential. </font>
  6. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    It may just be poor brakes, but it sure sounds to me like you have either a bad booster or no/improper vacuum going to it. The pedal having little travel would seem to indicate that your fluid brake system is ok (I would STILL check/adjust the rears) and a vacuum leak could cause the poor running of the engine you were talking about in addition to little or no brake boost.
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    no the poor running is a fuel supply issue by far(carb) i eliminated everything vaccum except the vaccum advance and the vaccum booster line. Neither is leaking by the carb cleaner spray test. If i disconnect the vaccum line the pedal becomes much harder. The brakes were new when I got the K5(put them on myself little over a year ago), but they only have like 5 or 6000 miles on them at best.
  8. JustHorsinArownd
    JustHorsinArownd Registered Member
    Mar 20, 2003
    77
    Flagstaff, Az.
    We have the same prollem on our 94 Suburban and it's the brake booster. It still holds a vacuum it's just the booster has gone south and we're just waitin for the pennies to add up to replace it. By the way, does it make a kind of a whooshing sound when you push the pedal down to stop? That's another tell tale sign. Good luck.
    Allan
  9. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    no whooshing sound I notice but yeah if you could hear much of anything over the headers straight into cherry bombs I would give you a prize.
