No brakes
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BLZN4FN, Apr 8, 2003.
  1. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    Ok after swaping the ft and rear axles putting
    SS brake lines no brakes. I have manual bleed the system no luck. I put my snap-on Vacula brake bleeder and ran about 1 gall
    of fluid still very little brakes. Replaced the master cylinder
    still no luck. Tapped on the porprtion valve no luck ayone have any ideas on how to get a good pedal??
    Thanks,
    Bo
  2. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Did you bench bleed the MC?Do you any pedal feel at all? or is just straight to the floor?
    Chris
  3. BLZN4FN
    Dec 19, 2000
    1,720
    Englewood Colorado
    Chris,
    Yes I bench bleed the master. The pedal goes almost to the floor I have a little brakes about 1 inch from floor.
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Did you bleed in the correct order? Farthest to closest to the master cylinder?
    RR
    LR
    RF
    LF
  5. BLZN4FN
    Dec 19, 2000
    1,720
    Englewood Colorado
    Yea I just went out and tryed agine still no luck.
    Is there a difference in a power bleader vs a vacume bleader?
  6. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    man do I feel your pain!
    Is the brake light on on your dash?? if yes- its the combo/prop valve...what I ended up having to do- was undo the lines on the valve..just left them connected - un screwed them etc..and pumped the brakes, that was enough fluid/pressure to get the flap in the valve back over to where it belongs.
    I gravity bled- till the fluid was pouring out of my bleeders, I manually bled till my leg was on FIRE....I vacume bled till the vacume pump caused a kink in my hand......it wasnt until I did this with the valve- AFTER hitting it to get the air out, that I got my pedal back......
    as an FYI- some vacume bleeders recommend (instructions say) to start CLOSEST to the master cylinder, not farthest away..
    good luck.....mine still arent the best- but my new calipers are sitting on my rear seat, waiting for the snow to leave again, so I can get them on- and bleed the front.
    Brandy
