No cat with TBI check engine light???
Discussion in 'The Garage' started by MTBLAZER89, Aug 31, 2004.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    If theoretically I was to remove my cat would this cause the check engine light to always be on?
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    o2 sensor is before the cat can't really see it causing a problem. I ran my 95 pickup with nothing more than Y pipe and a flowmaster 40 series with dual outlets. Never tripped the Check Engine Light. Heck running right out of the y pipe didn't /forums/images/graemlins/wink.gif.
  3. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    as long as you have OBD 1 you should have no problem
    if you have OBD 2 you need a o2 sensor sim from jegs or summit
  4. j20m715
    j20m715 1/2 ton status
    Aug 25, 2001
    1,056
    3
    Murphy,Tx
    I did this to a 98 truck & it did kick the light on.
    Without the backpresure it was confusing the computer.
    I ended up putting a hi-flo aftermarket cat on it.
    I know the tbi & vortec's are different but I think it will cause you problems.
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    your problem was simple, the 96+ chevys have at least 3 o2 sensors. 1 on each pipe of the y pipe, and one right AFTER the cat. This means if the cat is not there of course the system will know. It had nothing to do with backpressure.
  6. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    that is why you get a sim it plugs in where the o2 sensor was and tells the computer every thing is fine so you do not get any codes
  7. justinf
    justinf 1/2 ton status
    Sep 23, 2003
    684
    Tuscola, Illinois
    Nope, like Sled-dog I ran my old 90 stepside with headers, Y-pipe, straight into a flowmaster, no cat, and never had a problem. /forums/images/graemlins/waytogo.gif
  8. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Thats because OBDII has Pre and Post O2 sensors. On your '98 it has 4, and it would throw a code because both post O2 sensors will be switching, and there not supposed to be, not because of backpressure.
    No it shouldnt set a code on you TBI.
  9. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Gotta agree here. My '90 w/MPFI has headers, y-pipe into a Flowmaster. No problems.
  10. mosesburb
    mosesburb For Rent Premium Member GMOTM Winner
    Apr 20, 2003
    2,172
    128
    Phoenix AZ
    I have been running one of my TBI rides with no cat for over 10 yrs and have never set a code yet. These systems are archaic in today's technology (which is why I like them soooo much /forums/images/graemlins/thumb.gif).
  11. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    Bryan,
    No it wont. On our trucks the o2 sensor is in the driver side manifold. So it will not cause any problems by removing the cat. And all the shopd here wont take your cat off but if you dont have one they wont make you put one on either. So take it off.
  12. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    Brian, I removed the cat from my '87 & I have had no problems.
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    My 87 doesn't have a cat either.
    Hmm where the hell did it go? /forums/images/graemlins/rotfl.gif
  14. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    i just swapped my high flow cat out for a straight pipe when i installed headers. i had the muffler shop fab it up to be removable with 3 bolt flanges. so i can replace the cat when it comes time to smog it.
    i have found two problems with this. first, i can smell excessive exhaust odors, like unburned fuel that the cat would have cleaned up. now i cant have my back window down, or even the front window at lights without getting a nasty smell.
    second problem is now when i drive on the freeway, and just cruise with very light throttle, the light comes on. i think its a code 32. what do you guys think? i think i'll replace the cat and see if it goes away. i dont like the smell anyway.
  15. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    at this point I don't see a reason to not throw in a high flow cat. I'm going to on my Suburban, not my K5 just for ease but my next trail rig may very well get one.
  16. raelayotte
    raelayotte Registered Member
    Jan 22, 2003
    23
    Michigan
    i have had my cat off for 5 years know and no check light yet /forums/images/graemlins/k5.gif <font color="yellow"> </font>
