No clutch Pedal
Discussion in 'The Garage' started by chris12, Jan 3, 2007.
  1. chris12
    chris12 1/2 ton status
    Apr 23, 2006
    267
    Forest Ontario, 1/4 hr from Port Huron Michigan
    OK well on my 88 i still have no clutch pedal. It will engage but only when your foot is at the floor. IT has a new clutch ,maybe only month and a half on it, New slave cylinder, new hydro line, and a rebuilt mater cylinder. IV done the bleed thing by taking the slave off the bell housing and tipping it at a 45 so the bleed screw is facing up and got tons of air out. The problem is once i stop getting air, I hook it back up and still the same hardly any clutch pedal. And this makes it extremely hard to shift. Im bringing it to a local garage and they said they will try to bleed it through the reservoir. But what else good it be. Everythign is new. the slave cylinder and the master is about 2 days old no miles onit, As well as the new hydro line.
    Anyone have any suggestions.
  2. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Did you use a remand pressure plate? If so, alot of times you have to lengthen the slave rod.(make a longer one) If the clutch is engaging I would think that everything is working correct, you just need more pedal which is the slave rod. Just my .02
  3. chris12
    Apr 23, 2006
    267
    IM running a Zoom MU Series Cluch from Summit racing and they state in there catalog that it is a new computer tested plate.
  4. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    You must block the clutch fork from moving when you bleed it or you'll never get the air completely out of it. Use a block of wood to wedge somewhere between the clutch fork and the bellhousing or elsewhere so when you pump the pedal the fork can't move.
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Is bleeding it simmilar to bleeding brakes ? If so I like to run a hose into a bottle of fluid , so the air comes out , yet it can't suck any air back , only fluid .
  6. chris12
    Apr 23, 2006
    267
    alrighty will give it a go but how come they say in like manuals to take the slave off and tip it up then.
  7. chris12
    Apr 23, 2006
    267
    Yes forgot to add that. Thats how i was bleeding it that way it can only suck fluid in if it has to.
  8. chris12
    Apr 23, 2006
    267
    OK guys at the garage took ti for a drive and had a look. They said that there could be a possibility that a finger on the clutch is bent. Anyone heard of this.
  9. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Make a longer rod for the slave cylinder. It will take you all of 10 mins to make and change.
  10. chris12
    Apr 23, 2006
    267
    True. Since you are running the same transmission as me. Tell me how far you have to push your pedal down before it engages.
  11. clarkjw24
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I like mine to break about 4 or 5" from the floor.
    I don't have hydro on my rig but I'm speaking from expierence with the hydro stuff. On two other trucks I've had to make a longer slave rod after installing new pp and clutch. About a year ago I reworked a Heep comanche and fought with it for weeks trying to bleed it because I had no pedal. Then it hit me (because about 10 years eariler I had the same problem on an S10) that everything was working I just didn't have enough pedal. Simple solution, I took an old punch or allthread and made a longer slave rod.
    I'm not saying for sure that this is your problem but its simple enough to do and eliminate.
  12. CrewCab59
    CrewCab59 1/2 ton status
    Aug 13, 2005
    483
    Knoxville ,TN
    By making longer rod for the slave, all that's going to do is move the rod back into the slave cly more.The master cly tells how far the slave rod to go!Now making a longer or adjustable rod for the master will keep more pressure will push the slave rod out more!
    Now it also sound like you have air in the hyd system.
    Yes, You can bend a finger !
    Anytime you intall a after market clutch you should bolt the new clutch assy together and on the flywheel and install the whole assy in a press the check how much it's going to take to release it.( even they might say it's a stock replacment clutch).
    The next best thing is to go to a bigger bore on the master cyl .
    I ran into this with a SBC and the stock GM hyd parts wouldn' release it.
  13. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    mabey we can figure my problems out with yours and we can both have pedel.
    mine is 2-3 hits then no pedel. i have yet to remove and blead at 45 angle.
    but the slave i have is diffrent than origanal. old was stamped steal and new is cast steal. i wounder if there is a diffrence in bore and stroke as to old stocker.
