no code on jumping A & B with Paper CLIP
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by porkchop, Apr 30, 2002.
  1. porkchop
    porkchop Registered Member
    Apr 29, 2002
    21
    NH,seacoast
    Ok I tried the clip thing but got nothing now what?
    Really the only time I see the Service engine soon come on is when I pound on the pedel. If I just take in for an easy ride I get nothing Could it be the EGR?
  2. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    thats what mine was but this was from bridging a and b...you know which ones are a and b? which two were you using?
    Later
  3. porkchop
    Apr 29, 2002
    21
    NH,seacoast
    No clue I just walked and tried the norm.Got a clue for me I thought for sure It was the first left one and then the next on the top row? not to sure will try again in the am before work
  4. Rebel88
    Sep 7, 2000
    1,855
    Richmond, VA
    shoot ill have to find my manual but i think its the top and bottom terminals to the far right...ill check tom. but im pretty sure thats what it is...
    Later
  5. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    I thought it was the top and bottom to the left drivers side...but what do I know , But you will have a code saved in there just need to get it out....mike
  6. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    They should be marked. But I'd have a Chiltons in hand anyways.
  7. Rebel88
    Sep 7, 2000
    1,855
    Richmond, VA
    for my 88 my a and b plugs are on the right side of the plug...they are the two top terminals.
    Later
  8. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    You should always get some type of code. You should atleast get the all clear code. I think it is 13. I forget.
  9. Rebel88
    Sep 7, 2000
    1,855
    Richmond, VA
    12 is nothing wrong...13 is oxygen sensor
    Later
  10. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>It will flash 12 three times no matter what, this means its in diagnostic mode. Any stored codes will apear after this. Code 12 also means theres no distributor signal to the ecm. A and B are the two top right terminals
  11. FireBlazer
    FireBlazer Registered Member
    Apr 27, 2002
    10
    Milpitas, CA
    I just checked mine, the letters are on the plug at the top edge, you will probably need a flashlight/magnafing glass(depends on age) to read them. A and B are on the right upperside.
