No cruise and wipers only work on high
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Chris Demartini, Feb 17, 2002.
  1. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>The cruise control doesn't work on my 89, and the wipers only work on high (no delay or low speeds). Could these problems be related? Where should I start looking? TIA
  2. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Sounds like something in the wiper arm itself. Might wanna check it out.
    P.S. Nothingface is the sh!t
    Eric
    from Freekmont,CA.
    <a target="_blank" href=http://www.community.webshots.com/user/vwryda> Miscellaneous Debris </a>
  3. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    On crab'ed engines, no cruise indicates a vaccuum leak. I think my wipers also work off vaccuum (or was that the 72). Since yours in FI, it may not use vaccuum for these.
    Another thought, could it be a wire or something in your wand? (I'm talking about the control wand off the steering column that has wiper/cruise controls on it.) Or maybe the column?
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  4. Innerpiece
    Innerpiece 1/2 ton status
    Feb 22, 2001
    145
    Mississippi (Yee Haw)
    Do the wipers stop when you return to "Off" or do you have to work the switch to stop them? I've got a similar problem that I've traced to the "Park" switch. The wiper controller never sees "park" so it never stops ... nor does it stop, start the delay cycle, then start again.
    FWIW
  5. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>The wipers stop just fine.
