No doors
Discussion in 'The Garage' started by shaun, Jun 3, 2004.
  1. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    When you remove the doors, do you have to tie the two wires (in the door open indicator thingy) together or seperate them so not to cause the battery to die??? Or will just rewmoving the lightbulb work?
  2. dremu
    Feb 27, 2000
    15,963
    454
    East of San Francisco
    be thankful your door-open switch works. mine rusted shut years ago /forums/images/graemlins/laugh.gif
    -- A
  3. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    I don't know the light come off w/ the top on a 73 /forums/images/graemlins/grin.gif
  4. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    aren't you an electronics technician or something?? /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif The Haynes manual shows the door switch is normally open. Opening the door closes the switch and provides the ground. Take the switch out and cap each wire. /forums/images/graemlins/waytogo.gif
  5. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Sorry, I couldn't resist.
  6. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Take the bulbs out..... /forums/images/graemlins/whistling.gif /forums/images/graemlins/waytogo.gif
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    You could always hack into the wiring and install a toggle switch in the dome light circuit. /forums/images/graemlins/thumb.gif
    I've also seen Jeeps with a little metal clip in the door jamb. It could rotate around to hold the dome light switch pressed down all the time, for use with the doors off. Then when you put the doors back on, the clips get rotated out of the way. /forums/images/graemlins/cool.gif
  8. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    You can take out the bulb or put a toggle switch into the hot lead to the bulb so you still have a light when you need (or moreso your GF as I find a flashlight to be beyond convenient.
