no doors?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mud390, May 22, 2003.
  1. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    I was thinking about making my doors removable. Something similar to, dare I say it, a Heep. Anybody done this? I want to be able to put them back on though. I was thinking maybe some sort of pin in the hinge type setup. Any thoughts/help would be great. Thanks!
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I don't think the sheetmetal is up to the job. Our doors are a "little" heavier than heep doors.
    -Brian
  3. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    I just did this.
    I found on here how to get the hinge pins out easily. Weld a washer to the top of the pins. Grind or file off the knurls from the hing pins.
    The only problem is the top hinge pins will not go in from the top. You have to put them in from the bottom. With the washer there, you can put a wire through the hinge pin and hold it onto the door hinge. They do tend to slip once in while. You will be able to tell when the door doesn't align any more. Push it back in.. voila'
    I also re-aligned my hinges with new bushings and all is well. The doors go back on with no more re-alignment problems.
    BTW: It's illegal in CA to drive without a drivers rear-view mirror and a center rear-view mirror.
    I am working on a mount to use the (windshield frame) tops bolts to mount the driver's rear-view mirror.
  4. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    my doors r removeable...its pretty simple. Basically u go to the parts store and get 4 longer-than-stock door pins + replacement bushings + 4 lil cotter pins. Basically u swap these pins in for your factory ones. The pins are so u can keep the them from popping out (the top ones r upside down). Use a grinder to make a flat spot at the end of the pin, then drill a small hole through the door pin thats big enuff for the cotter pin to push through. Presto, u have removable doors. To make pulling the pins easier, weld a washer to the top of each pin... this lets u put a screwdriver in the hole and pull em out. Needle nose r good for the cotter pins. I made mine removeable so I can put tube doors on. i could prolly post a pic when i get home tonight..
    j
  5. deek
    deek 1/2 ton status
    May 6, 2003
    142
    Great Bend, KS
    yeah, some pic's of the removable door hinges would be great
  6. mud390
    Oct 31, 2002
    1,210
    I second that about the pics.
  7. BiggerIsBetter
    BiggerIsBetter Registered Member
    Aug 9, 2002
    23
    Livermore, CA
    Are there laws regarding taking your doors off? I heard you have to have a 3 inch lip on the door frame so nothing can fall out. Anyone know if its true?
  8. deek
    deek 1/2 ton status
    May 6, 2003
    142
    Great Bend, KS
    well see your from CA,, so probably, Man that state doesn't let anybody have fun, whats up with all the rules out there?
  9. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    ok, Ill borrow my dads digi-cam and see if I can get a pic up. Guess my descrition was sorta confusing. /forums/images/graemlins/grin.gif
    j
  10. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    If it's not a constant on and off thing, just unbolt em, it isn't to complicated. But a slide in with pins would be cool. Tube doors are nice too *cough cough*. I can give you plans to make some if you are so inclined /forums/images/graemlins/smile.gif
  11. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    pic is posted in my pre-BB build up album... just have to wait for webshots to put it up and we're in business... /forums/images/graemlins/grin.gif /forums/images/graemlins/thumb.gif
    j
  12. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    here it is...
    pins
    doesnt show tooo much, but then again it is a pretty simple mod....
    j
  13. deek
    deek 1/2 ton status
    May 6, 2003
    142
    Great Bend, KS
    thanks man! /forums/images/graemlins/thumb.gif
  14. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    no problemo... /forums/images/graemlins/grin.gif
    j
  15. mud390
    Oct 31, 2002
    1,210
    Thanks man! I really appreciate it! Its a lot easier than I thought it would be. Looks like I have myself a new project for my rust bucket.
  16. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    I went the longer route. Take the hinges off. Remove old pin and bushings. Drill so that 3/8" grade 8 bolt will fit through. Go to machine shop and buy 3/8" inside diameter 3/4" outside diameter bushing stock. Weld that inside the male side of the hinge. Also weld 5/16" washer on top and bottom of this hinge peice. female side of hinge weld a small peice of bushing stock top and bottom. All you really need to do is tack this stuff together. If you ever have to redo it. Now insert 3/8" x 5" bolt and wallah. Now you have enough surface area against the bolt that the thing will never wear out. Pull two bolts and you are done. When you put the door back on no adjustments are needed. Mine ended up so tight I think the door would close with one hinge pin out.
  17. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    yeah, i have tube doors, so i have to do some adjusting of the striker bolt etc cause the factory door and the tube door arent EXACTLY the same length... otherwise the doors just go on/off np. Its no biggie, 5 mins with a tor-x and some washers for spacers.
    j
  18. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i called the state to ask about not having doors on a pickup and they said no, but ive driven a couple withotu doors before, for short period of time,
    its different, hehe
  19. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    afaik, most states dont have a "u must have doors law"... what they have is "u must have a drivers side side-mirror" rules etc.... I just attached one to my tube doors and all is good.
    j
  20. win717
    win717 Registered Member
    Mar 8, 2003
    60
    PA
    I'm going to make a set of pins up for my 79 blazer,anyone have any ideas on where to relocate the mirrors?Pa says I MUST have them
