no fire
Discussion in 'The Garage' started by jeff l, Apr 26, 2007.
  1. jeff l
    jeff l 1/2 ton status
    Jun 13, 2006
    104
    New Orleans
    My 79 350 is not getting any fire, any ideas where to start,
    Thanks Jeff
  2. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    Maybe the lil dealio thingy inside the dist. Electronic gizmo that has 2 connections at each end. Sorry if I'm talking over your head. Not to toot my own horn but I'm really knowledgable in this ignition stuff as you can see.
  3. slyguy_22
    slyguy_22 1/2 ton status GMOTM Winner
    Dec 13, 2004
    789
    Lancaster, PA
    Check ur coil. cap and rotor for corrosion. and battery connections. also the wire from ur starter to the coil.
  4. jeff l
    Jun 13, 2006
    104
    New Orleans
    Thanks, I did see some corosion, and tried to scrape it off, maybe I need a new one.
  5. TexasBlazerBoy
    TexasBlazerBoy 1/2 ton status
    Oct 10, 2005
    1,674
    North Texas
    Ignition module, maybe?
  6. dyeager535
    26,982
    191
    You've got 12V on the pink wire to the distributor, with the key in "run"?
  7. jeff l
    Jun 13, 2006
    104
    New Orleans
    I am going to check that now, Thanks
  8. jeff l
    Jun 13, 2006
    104
    New Orleans
    Yes, I do
  9. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    either the coil is bad. or hte pickup coil is bad. (what mudstud was describing)
  10. jeff l
    Jun 13, 2006
    104
    New Orleans
    Thanks all, I just finished, I have a 79 new rebuild, w/ a 86 ES HEI, that I jumped wires and made a regular HEI; never was a 100% that it was the corect way to do it, but it worked for 8 months. Anyway I put a new HEI,cap,coil,rotor, and now I have spark.
    Thanks---Jeff
  11. BlazerBud
    BlazerBud 1/2 ton status
    Jun 14, 2006
    473
    Chattanooga
    Get someone smart to look at it in person
  12. jeff l
    Jun 13, 2006
    104
    New Orleans
    What do you mean:confused: :confused: :confused:
