No front brakes??
Discussion in 'The Garage' started by 90blzr, Dec 28, 2005.
  1. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    Okay, 90K5, D60 up front 14bff rear disk, stock K5 booster, master, and proportioning valve, etc.
    Bled everything (or it appears I have). Rear brakes work cherry, the front brakes dont do sheit. They are barely taking the surface rust off the rotors....just barely.
    Any suggestions?
  2. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    master is to small for the bigger calipers.
  3. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    hmm looks like im gonna be in the same boat, i jus went from 10b front and rear to 60/14. so will just a 1ton master fix the problem, or is other stuff needed as well?
