no front driveshaft..problem?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jekbrown, Feb 20, 2002.
  1. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    I need to drop my t-case with the spacers to help solve a post-shackleflip + ord zero rates install vibe problem. problem is, the front drive shaft hits the exhaust x-over when I do this. Is there any reason why I can't, for the time being, remove the front drive shaft? Will the rig be driveable in 2wd mode still? Just thought I'd ask before I try it...I dont see a problem...but I am not a tcase guru either...
    I need to get that stupid exhaust x-over pipe fixed...
    J
    See the on-going build up of my '85 Jimmy! <a target="_blank" href=http://community.webshots.com/user/jekbrown>http://community.webshots.com/user/jekbrown</a>
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    yes you can. I did for a while in my 79 when I swapped axles, and I also did the lock the hubs and use the front while I had no rear driveline( low range+ railroad tracks= driveline bails out)[​IMG]
    <hr></blockquote>
    What do you mean, Where did I get it??...I <font color=blue>BUILT</font color=blue> the damn thing!!
  3. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    yes... i'm driving w/o my front one in right now... I threw some hubs up front and took out the driveshaft till i get the part time kit in the xfer case.. np203...
    Works fine I just have to drive in 4Lock w/o the hubs engaged...
