No front wheel cylinders????? HELP!!
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by aksidentproan, Jul 3, 2002.
  1. aksidentproan
    aksidentproan 1/2 ton status
    Dec 8, 2001
    477
    Maryland
    Redoing the brakes and I need front wheel cylinders. Called 5 parts stores, including NAPA, and in there parts book it says "NOT AVAILABLE". Any suggestions? They have the 2wd ones but not the 4x4. Are they the same? I'm in need of some serious help. Thanks
  2. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    Did you try LMC, Chevy Duty or any others? LMC has them listed for 4wd at $29.95 each.
  3. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    seems like it's time to switch over to disk brakes. have you tried the other local parts stores. also you can look or ask around for truck(not blazer) wheel cylinders. just take yours to compare them. you can also try and rebuild them by purchasing the rubber pieces themselves.
    ARQ.
  4. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    thats the cheaper way to go also.cost me 5 dollars for a rear brake cylander rebuild kit for my 12 bolt.only takes about 10 minutes to replace the rubber seals.
  5. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    look what i found, second page link below. you can get the part numbers and go to the local parts store to see if they carry them.
    good luck,
    ARQ.
    wheel cylinders
  6. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    Went through the same thing, I took one off and took it to napa and the PN on my wheel cylinder crossed to a 1969 cylinder and that's what I put on PN 14493 and 14494.
  7. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    If you haven't found any yet let me know, I can check at work tomorrow and get you all kinds of part numbers for them.
  8. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    i ran the parts numbers on mine. they are same all the way through to 72. my truck is a 69 and i had to tell them 72 so it would show available. then the screen said 68-72 on its description. good luck
    nathan
  9. POFF
    POFF 1/2 ton status
    Aug 13, 2001
    221
    San Diego, CA
    I'm pretty sure I got mine at Kragen. Ask them to look in the book if it doesn't show up in the computer. If they give you a hard time, ask if you can look it up in the book. I do it all the time. '70 Blazer? I have some brake catalogs at home, I'll look up the Raybestos and Bendix part #s when I get home from work.
  10. POFF
    POFF 1/2 ton status
    Aug 13, 2001
    221
    San Diego, CA
    Bendix ('69 only listed)
    Left: 33501
    Right: 33502
    Raybestos ('69 only listed)
    Left: 14494
    Right: 14493
    NAPA
    Same as Raybestos
    There's a place in Spring Valley, CA called Border Parts. If your set on keeping the drums John can find them.
    If you want to convert to disc, It's really easy. It's all bolt on. I spent $200 more on converting to discs than I would have spent on fixing the drum brakes. All the brake parts are in stock and really common. Calipers at Kragen were like $18, wheel cyls. were $40. Drums were $80-$100, rotors were like $30. If you need help with info on a conversion email me.
