No Fuel!!
Discussion in 'The Garage' started by MITCH_89', Apr 2, 2003.
  1. MITCH_89'
    MITCH_89' Registered Member
    Dec 7, 2000
    91
    GULF BREEZE, FL.
    I rolled to a stop, and there it sits..broke. /forums/images/graemlins/frown.gif
    Got spark, no fuel. I took the filter off the frame, and turned the key on, no gas. Should gas spray out when I turn on the key? Fuel injection
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Sounds like a bad fuel pump. Its in the tank. Hopefully the tank isn't full. Mine have always gone bad right after I fill them up. /forums/images/graemlins/tongue.gif
    Get yourself a new pump, sock, and new filter. You should be fine after that.
    John [​IMG]
  3. ds350
    ds350 1/2 ton status
    Jan 26, 2001
    190
    Bay Area
    There is a relay in the engine compartment that you can Jump with 12V to run the fuel pump. If the pump is working, you will hear it run....if not, time to pull the tank. Be sure and check the Baffle in the tank, they are know to come loose, and wreck havoc on the sender/pump assembly.
  4. themaddhatter
    themaddhatter Registered Member
    Apr 16, 2002
    24
    even if you jumper it and you hear it run, it may not be working STILL
    If you have power going to the pump, can HEAR the pump, but aren't getting anything at the filter, get ready to crack that tank open....
    good luck
