no fuel
Discussion in 'The Garage' started by georgiared84, Jul 30, 2003.
  1. georgiared84
    georgiared84 1/2 ton status
    Sep 5, 2002
    487
    Austell, Georgia
    picked up a 72 with a new crate 350 in it this weekend. Not running because the former owner got tired of working on it before he fin ished the install. I'm not getting any fuel up to the carb. I just put on the pump. Positioned the pushrod on the pump lever corectly and hooked up the lines. Cranked it over for several minutes with no fuel coming up the line. Any suggestions? I'm kind of stumped.
  2. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Any fuel in the tank?
    Doe's it have an auxillary tank? If so, is the valve turned to the correct tank?
  3. georgiared84
    Sep 5, 2002
    487
    Austell, Georgia
    tank is half full. Only one tank. I'm not even feeling any presure from the hose when the engine is cranking over.
  4. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    It is possible when installing the fuel pump, to have the pushrod slide down and still get the pump on the engine.
    Pull the pump and take a look. A hacksaw blade work's well to hold the pushrod up, while installing the pump. Another method is to remove a 3/8" bolt on front of the block, replacing it with a longer bolt, to hold the pushrod in the up postition, just remember to remove the longer bolt, and reinstall the shorter bolt, with a little "Right Stuff" on the thread's. /forums/images/graemlins/grin.gif
