No go
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NoSmog73, Jan 13, 2004.
  1. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    Ok for starters it is a c1500 1989 chevy 350tbi and I was checking to trouble codes by jumping the A and B terminal with a jumper wire and when that was done I pulled the wire and shut the key off...Then reset the brake light switch and went to start it and.....
    Nothing...
    I got power to the fuse panel..Power at the back of the alt from the starter...I have the fan,radio,lights,all that just no turn over,nothing ...not even a click..but the dash instuments go over to the right like it was starting...Any ideas..
    I have looked for a fused link from the battery to the starter and didnt find one.
    Checked the fuse panel and all items on it have power..
    I am at a loss...Anyone have a or know where there is a wiring diagram of this truck...Mike
  2. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    did u check all the fuses? pull them and look to see if any are burned up.
    Nick
  3. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    yea that was me first thing I did.. /forums/images/graemlins/thumb.gif
  4. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    You have power at the starter?
  5. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    Yea I have power at the starter and it carries to the alt..bolt in back also...I might just change to starter and see if that works...
  6. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    how much power at the starter?? full 12 volts?
  7. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    I dont have a volt meter just a test light...I see a trip to the tool store coming...lol
  8. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    Take your test light and a buddy and check to see if voltage is makin it to the solenoid. Buddy to turn the key and you and the test light to check the wire. Good luck to ya.
    Allan
  9. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Sounds like the selonoid. Try tapping on the selonoid while someone tries to start it.
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Take the starter off and have it tested.
  11. BigDummy89K5
    BigDummy89K5 Registered Member Author
    Mar 8, 2003
    77
    Abbottsford, B.C.
    i had the same thing with my truck everything worked but no go.you think it will be the big money things at first.and most of the time it is,but for me it was a bad battery ground,motor end.good luck /forums/images/graemlins/thumb.gif
  12. big k5
    big k5 Registered Member
    Nov 19, 2003
    88
    Sautee Nacoochee,Georgia
    could it be when you were checking your computer codes somehow the computer is hung up ??? maybe if you just disconnected your battery to clear the computer it may start.???good luck, Bruce
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Make sure the fusable link on your firewall is good on the driver's side. That's where the column gets its power. Mine burned and my truck wouldn't start.
  14. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] I was thinking the same thing. Plus disconecting the battery for 5 mins. is free, and doesn't hurt to try.
  15. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    Ok this goes in my DUH book...(as I smack my head)
    Well I changed the battery from the blazer to the truck and it fired right up....I thinks it time for a new battery or alt...
    Just makes me mad I didnt check that area first other then visual..
    Anyways thank you to those that replied ...
    /forums/images/graemlins/rotfl.gif
  16. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    /forums/images/graemlins/blush.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  17. Ryan B.
    Jul 18, 2001
    5,693
    CA
    hehe.. yes... geez you guys, the first step of a no start diagnosis is to qualify the battery..
    -Is the battery charged? is it at 12.4 volts or higher?
    /forums/images/graemlins/blush.gif /forums/images/graemlins/grin.gif
    Take the starter off and have it tested before checking battery voltage huh? Hey 84K10 you can come work on my junk anytime! /forums/images/graemlins/ignore.gif /forums/images/graemlins/rotfl.gif
  18. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Sorry, I guess you just assume that someone would try to jump start it first, before anything else.
    Guess that's I get for ass/u/m(e)ing
  19. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Same here...I just figured he already ruled the battery out.
  20. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Yah agreed most guys the battery would be the first thing to check, but we can't assume everyone on here asking for help checks the little things first.
    This is where i started really scratchin my head about how he qualified the battery! /forums/images/graemlins/thinking.gif
