No Headlights, Turn Signal, Oil Pressure, And Beeper...
Discussion in 'The Garage' started by beastofablaze, Apr 15, 2005.
  1. beastofablaze
    beastofablaze 1/2 ton status
    Apr 4, 2005
    441
    CA
    I Hooked Up My Battery Wrong And Got A Pretty Good Fireworks Show From The Terminal And Now I Have No Headlights, Turn Signal, Oil Pressure (gauge), Or Beeper When The Key Is In The Ignition And The Door Is Open..... No Blown Fuses. What Should I Check?
  2. dyeager535
    26,980
    Fusible link coming off the starter to the terminal on the firewall. All the wires at that terminal should have 12V IIRC.
  3. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    ECM.....Ask me how I know :frown1:
    Rob
  4. beastofablaze
    Apr 4, 2005
    441
    CA
    well the ecm should be ok because i have turn signals front and rear after i pulled the solenoid and soldered up the short stud to keep it from flopping around but i still have no oil pressure gauge or headlights... I am going to get a direct oil pressure unit and a T fitting to run stock and aftermarket oil pressure gauges but i NEED headlights... what else is there? all the wires look good. Is there a switch or fuse i'm forgetting?
