No heat need help
Discussion in 'The Garage' started by adamforsythe, Dec 27, 2004.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    The heat in my rig does work but the fan blower does not. what could it be, did I unplug something when I put my new intake on or my new CD player?
    Adam
  2. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    blower motors are cheap. check the wires going into the blower motor for power. some have a resistor that gets corroded but most you just have to put a new motor in. super easy and not tooooo expensive. or you could have hit a wire/ vacuum line coming from the switch. check for power first then go from there. also you can eliminate the switch to see if the blower works. take one neg. and one pos. wire and touch them to the corresponding wires.
