No Heat!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by foxman, Dec 3, 2002.
  1. foxman
    foxman 1/2 ton status
    Oct 22, 2001
    251
    Detroit MI
    I'm freezin, this puppy takes forever to heat up, and when it does, the heat is luke warm, doesn't even heat the front seat area. the engine temp bounces off 100 degrees. I know I put the 180 thermostat in it to keep the temp down over the summer, but is that really why I get no heat?, I mean, 100 degrees ought to be enought to heat the hell out of the truck, no? What elese sould I do to stop my truck from acting like an ice box? Thanks....
    Jeremy /forums/images/graemlins/angryfire.gif
  2. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    Make sure your thermostat isn't sticking (open), and check your radiator cap, too. If the system isn't pressurized (sealed), it won't heat up properly.
  3. dyeager535
    26,978
    A 180* thermostat alone won't keep the engine temp at 100*. Is it really that cold first off (if you have no heat, it very well may be) but at 100*, you won't even be building pressure in the system.
    Feel the upper hose, if its still cold, or just kind of warm (not hot) after the vehicle has been run, shut it off, take a rag, put it over the cap, and loosen it. See if any pressure has built up. If it hasn't, and if you are adventurous, dip your finger in the radiator fluid and see how hot it is. It may sound stupid to try, and the upper hose should tell you if its warm or not, but the water should be around 180*, which is darn hot.
    If it's not hot, I'd suspect a faulty thermostat, installed incorrectly, or of course, the ever present "something else". Robertshaw/Mr Gasket thermostats seem to have some quality control problems, so if you've got one of those, you very well may be looking at a faulty thermostat. Before anyone gives me crap about saying they have some quality control issues, I know people that swear by them too, but there are just as many people saying they like to stick open or closed even when brand new.
    With no thermostat, my car (307) wouldn't get over 100 either, no matter how hard I was beating on it. No system pressure, and the coolant wasn't even close to hot to the touch.
    A 195* will give you a bit more heat, and there is no reason to run anything lower except if you take it to the track.
  4. kumma
    kumma 1/2 ton status
    Oct 29, 2000
    380
    Novi, Michigan
    man it was 9 degrees in brighton this morning, my truck usually heats up quickly, but today it took quite a bit longer, turns out the antifreeze actually froze. you might want to check out the mixture in yours. i still had ice on the floor of my truck when i got to work, no carpet in mine.
    craig
  5. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    when its like that out side i let my truck warm up alittle bit, like 5 minutes or so before i head over to my friends house in the morning and we goto school. /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  6. Marshall
    Marshall 1/2 ton status
    Apr 8, 2002
    204
    LiveRmore,CA
    well......be happy your engine is runnin cool.
