No injector Signal
Discussion in 'The Injection Section' started by 1979jimmy350, Sep 5, 2006.
  1. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    ON my blazer im not getting and injector signal, i can crank and crank and it will not start, im getting 40 psi of fuel pressure and i am getting spark. If i spray fuel down the throttle body it will run for a little bit
  2. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    From the manual assuming fuel pressure as stated:
    1. Check all electrical connectors and grounds related to the system.
    2. Check the battery for full charge.
    3. Disconnect the injectors and measure the resistance of each injector, compare the resistance - should be 1.16 to 1.36 Ohms.
    4. Turn the ignition key on and check for battery voltage to the injectors at the injection harness connectors, if there is no voltage present check the fuse and related wiring.
    5. Install an injector test "noid" light at each injector electrical connector one at a time. Crank the engine over and confirm the test light flashes evenly on each injector connector. If the light does not flash have the ECM checked at a dealer.
  3. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    ok, i checked all the connections there fine, the injectors are spec at around 16 Ohms, when i crank the engine im not getting the injector pluse at all
  4. CB77GMC
    CB77GMC 1/2 ton status GMOTM Winner
    May 6, 2005
    771
    Heath Springs, SC
  5. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    being that i am not getting a aldl data streem also i think i am going to just buy a new computer and see if that takes care of the problem
  6. jamber2541
    jamber2541 1/2 ton status
    Apr 10, 2006
    424
    e.p. texas
    take your ignition module to a parts store to get tested, it also controls the injector pulse
