No Low No Way!!!!!!
Discussion in 'The Garage' started by Clod_King, Oct 5, 2005.
  1. Clod_King
    Clod_King 1/2 ton status
    Jun 7, 2005
    1,094
    Grimsby Ontario
    okay so I have an NP203, and it won't engage Low Lock. But the other 4 settings work fine. High lock works fine, high works fine, neuteral, is well..... neuteral, and low works fine too. I have been offroading in 4hi lock, but I want the low lock. please help me, I cannot crawl if my truck can only run!
  2. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    will the shifter not physically allow itself to be pushed into low loc or does it not lock up when you get it there?
    i wouldn't be surprised if it was just a really worn linkage...the 203's are notorious for sloppy linkages. i know mine is.
  3. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    I second what Matt says. I had a 203 that shifted horribly and always popped out of low lock. Messing with the threaded adjustments on the shifter helped some but I never did get it to work right.
  4. Clod_King
    Jun 7, 2005
    1,094
    Grimsby Ontario
    is there any way to fix it at all. my shifter will not even go into loc. I've tried everything. well I geuss I haven't tried stomping it into gear with my foot yet, but I mean i don't really want to do that. I would like to know how to make the thing work. what if I replace all the linkages?
  5. bugspray
    bugspray 1/2 ton status
    Jan 13, 2004
    110
    Phx, Az
    Twin stick it! That's what fixed mine.
  6. big d
    big d 1/2 ton status
    Oct 24, 2001
    1,236
    illinois
    crawl underneath and spray lube the hell out of the linkages, make sure they r clean as well. thats what was wrong with mine. good luck.
  7. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    I had a 79 Dodge with that problem. Replaced all the linkage bushings, adjusted and lubed all the linkage, finally got it to work. First thing I did was unhook the linkage, crawl under and put it in low loc by hand, to make sure the TC was not the problem, then worked backwards from there.
  8. Clod_King
    Jun 7, 2005
    1,094
    Grimsby Ontario
    can I take the brace that runs underneath my t-case off? I don't know if it supports it ornot, and I can barely get my hands up there with it on. I already sprayed the crap out of it with WD40. can I get a rebuild kit? I mean to replace th linkage parts?
  9. Brocky
    Brocky 1/2 ton status
    May 22, 2005
    1,170
    St.John's Newfoundland, Canada
    :haha: :haha: :haha: The foot doesn;t work either, tried that. Does who know the 203 will understand. I went into a bog hole and got stuck, then my buddies starts yelling at me saying my tires weren't spining on both axles. I cursed and swore and kicked it. Had a job to get it out. Anyways I cleaned mine up before and it worked well for a while (2 years) now I am having the same problem again. I have a sm465/205 combo I am putting in so I will not be fixing it, but if I were you I would twin stick it if you plan on keeping it under your rig.
  10. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    DO NOT remove the t-case crossmember unless you have another means of supporting the t-case/trans assembly. Not unless you want to look like a squished grape.
    To adjust your linkage put your shifter in neutral. If you look at the shifter assembly you'll see the shifter mechanism hooked by two rods to the t-case shift arms. Make sure the t-case arms are straight up and down - that's neutral.
    Now move back up to the shifter mechanism. There is a small round hole in the lower middle area of the housing that will line up with the exact same size holes in the shifter levers. Just take a drill bit that fits that hole and run it through the shifter lever holes. These 3 holes should line up with the t-case in neutral (t-case arms straight up & down in the 6:00 position).
    If it doesn't line up then adjust the shift rods until they do. The shift rods have adjusting nuts on them so you can lengthen or shorten each rod. By adjusting the rods you can line up the holes in the shifter/lever arms making sure the t-case arms are straight up & down while in neutral. You have to be patient and lay under there with an open end wrench to adjust the rods. NOTE: There is a lock nut butted up against the adjustment nut, you have to loosen the locknut 1st then you can turn the adjustment nut. There isn't much room but you can do it. Just make sure to retighten the locknut once the rod is adjusted.
    If this confused the crap out of you just go pick up a 10.00 Haynes manual for your K5 with illustrated instructions.
