no more points!!!!!
Discussion in 'The Garage' started by chevy wrangler, Jul 5, 2006.
  1. chevy wrangler
    chevy wrangler 1/2 ton status
    Jun 15, 2006
    3,035
    el paso, texas
    i cant seem 2 gap my points right i know its suppose 2 be at .019, but cant get it gapped!!!!:mad: :mad:
  2. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    If ya have the money, get a dwell meter. It gets the points right on. And remember, changing the point gap changes the timing a bit. Ya need to set it each time ya adjust the points!
  3. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    just go hei, get one from a junkyard and live happily ever after:D
  4. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    I bet there are some youngins in this audience, who have never even heard of such a tool or even the term "dwell". :D
  5. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,602
    551
    Wasilla AK,
    I've heard the thickness of a match book is about correct but I'd just get an hei or an elctronic conversion for your points distributor
  6. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    how do i convert it 2 HEI??? dwell is how long the points stay closed right??
  7. yellowK20
    Dec 26, 2002
    7,602
    551
    Wasilla AK,
    get an Hei distributor what yera is your truck????
  8. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    You learn quick young grasshopper. :D
    Switching to an HEI is easy. Pull your points distributor and coil, drop in an HEI distributor and then check voltage to the wire that was originally going to your positive side of the coil and if it's 12 volts put a connector on it and plug it into the HEI cap where is says BAT and you're all done. :thumb:
    PS: This will however cause you to need to buy new plug wires and a different style coil and cap but probably time for that tune-up anyways.
  9. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    its a 1979 but has a 1969 chevelle 350
  10. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Your truck originally had an HEI distributor in it. I'll bet you keep eating points because you cannot have more than 9 volts on a points distributor or else points fail very quickly unless of course someone was smart enough to install a ballast resistor or a resistor coil.
  11. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Don't fergit to increase the size of the wire going to the dist. I had weird problems on my '73 when I put in a HEI, until I did.
    Run a 12 or 10 gauge from a "switched" terminal on the fuse box to the dist. It will be "hot" 12 VDC when the ing switch is turned on.
    Note:
    Unless it had HEI originally!
  12. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    well it has had that distributor in it for like a yaer and thats the first points i burned, i left the radio on, oopps!!!LOL
  13. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    whats the best thing 2 do??? i dont want to throw the timeing off............and well i do have a HEI on my project blazer, so yeah what should i do?????
  14. yellowK20
    Dec 26, 2002
    7,602
    551
    Wasilla AK,
    Just go get you another HEI there cheap try one of those junk yards on montana out by the titty bars
  15. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    yeah but wont it knock the timming off???im not good at stuff like that!!!!LOL
  16. yellowK20
    Dec 26, 2002
    7,602
    551
    Wasilla AK,
    just pay attention to where the #1 plug wire is on your current Dist' and put the new one in the same way it's not as hard as it sounds if you can set pounts then you can swap distributors
  17. yellowK20
    Dec 26, 2002
    7,602
    551
    Wasilla AK,
  18. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    yeah but i cant set points???
  19. yellowK20
    Dec 26, 2002
    7,602
    551
    Wasilla AK,
    Oh, well uhhh.... is this your only vehicle ???? other than your project mentioned above
  20. yellowK20
    Dec 26, 2002
    7,602
    551
    Wasilla AK,
    if you could get the truck up here to Alamogordo I sure wouldn't mind helping you convert it to HEI
