NO more sparks please
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 91gmcjimmyCH_IL, Sep 4, 2001.
  1. 91gmcjimmyCH_IL
    91gmcjimmyCH_IL 1/2 ton status
    May 24, 2001
    110
    Grayslake, IL
    I'm trying to put in an aftermarket tach in my 91 jimmy and am having a little bit of problems. First off is the wire i get the tach inout from the one that hangs off the ignition coil that goes about 2 inches and then stops. second where can I get power for the tach from. I tried the radio not a good idea. then i tried ACC on the fuse box i'm not sure if that works. Please help before i have little red splitter on everywire under the dash. one more thing whats the easiest way to get the light for the tach hooked up.
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Easiest way to hook up your light is off of the "LP" terminal on your fuse block. For a power lead, hook it into one of the the "IGN" terminals on the block - this should have you good to go. All you'll need is a couple of .25" male spade terminals.
    1 tequila 2 tequila 3 tequila Floor
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
