No More Stupid Questions
Discussion in '1992-Present Chevy & GMC models' started by Yohinan, Apr 26, 2004.
  1. Yohinan
    Yohinan 1/2 ton status
    May 21, 2003
    103
    San Diego
    Ok no more silly questions from me. /forums/images/graemlins/1zhelp.gif Here comes one that may be a little wiser hopefully. Is there any way to avoid the 1k-1500.00 prices I keep seeing for IFS Suspension lifts? I can do the 4" shackle flip in the rear but is there any way to get a 3-4" lift in the front without spending that kind of dough or do I have to bite the bullet? /forums/images/graemlins/confused.gif I see some 3-4" suspension lifts from JCWhitney but not sure if they will work or not. They are by Rough Country and also Superlift. I am looking for something in the 300-400 dollar range if possible. This again is for my 95 Chevy Suburban 4x4. Thanks again for all the help. John
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    nope. its not avoidable. The only cheap kits are the 2.5" lifts and they are in your range but don't do much. A truck with a 2.5" lift looks like you would think a good truck should sit. Like was noted in the other thread, the lift kits for IFS trucks, they are all brackets, they drop the mounting location of the control arms, the differential, and the crossmember for the torsion bars. In the end its a lot of parts and brackets and engineering. Basically for now IFS kits are expensive and going to remain so.
  3. Yohinan
    May 21, 2003
    103
    San Diego
    Well good news everyone. I just found one decently priced. Sometimes I surprise myself. It is amazing what a little research can accomplish. I found a 2-3" lift kit for 379.00, made by Rough Country. That along with another item will give me the 4" I was looking for. Sweeeet. Thanks again to a great site! John
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    Did you read my post? The 2-3s aren't great kits. They replace one a arm, cause balljoint and CV wear and I really don't like them. Go to fullsizechevy.com and ask what they think about 2-3" kits. I really don't know how they will feel just that they deal more with IFS than this site.
  5. retroblazer
    retroblazer 1/2 ton status Premium Member
    Nov 30, 2003
    284
    156
    Gustine
    Note the reponse of the last guy. Those kits will do little and will likely diminish the quality of the ride. The question is why are you looking to raise the truck?
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Read the fine print in the instructions VERY carefully before you start installing one of those. I was at a local Discount Tire store one day when a customer came into the store in a total panic. He had bought one of those kits and was having it installed at a repair shop. Once it was all installed they found out that his wheels would NOT bolt back onto his truck. /forums/images/graemlins/yikes.gif That's when they noticed in the directions that the kit would work ONLY with wheels that had a certain offset. The Discount Tire guys couldn't even find any wheels in their catalogs that had that particular offset. /forums/images/graemlins/eek.gif The guy was freaking out. /forums/images/graemlins/frown.gif
    Raising a GM IFS truck three inches without lowering the diff is going to put your CV joints at an extreme angle. And since they are spinning any time you're driving, you'll need to get really good at replacing CV shafts. /forums/images/graemlins/frown.gif
  7. tweaker
    tweaker 1/2 ton status
    Mar 21, 2004
    263
    Modesto, CA USof Freakin A
    if you know of anyone going westcoast to east coast, i've got a 4-6" rancho kit for $900. the kit includes arms, balljoints, 3/4ton torsion bars and much more.
  8. Yohinan
    May 21, 2003
    103
    San Diego
    So what you are saying is if I go with a lift without spending like a 1000.00 it is not going to be a quality lift and I will run into problems? My goal was to not spend that kind of money as I dont have it. More dilemna's from what I am hearing. Thanks for the help. John
  9. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Why do you want to lift your truck?
  10. Yohinan
    May 21, 2003
    103
    San Diego
    To get 33" mud tires to fit. I like to have fun offroading once in a while but I dont go enough to want to put one of the "bigger" lifts on that are out there. I plan on getting rid of the Suburban early part of next year for a newer 2500 Suburban that I am going to go "wild" with on the lift. Those are my plans for right now. John
  11. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Just slap a set of 32's on it instead of 33's. They should clear the fenders and you can save the rest of the money for the 2500. /forums/images/graemlins/thumb.gif
  12. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    body lift is also an option...
  13. 89K1500Chevy
    89K1500Chevy 1/2 ton status
    Nov 9, 2002
    645
    Georgia, Fayetteville
    33's with no probs will be going to 35's next on the same set up
