No oil going to the topend.......
Discussion in 'The Garage' started by 84CUCV, Apr 19, 2005.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    Well, actually it’s the passenger side, two up front of nothing coming out. The others shoot out like crazy. The motor has 600 miles on it. its in a 90 sub. All the lifters are new. I would be something in the top end right?? I don’t see how it could be in the bottom end. I am giving this one last try. Any help would be great.
    thx mike
  2. diesel4me
    Jul 24, 2003
    17,569
    943
    Massachussetts
    Pushrods clogged???
    Strange only 2 have no oil!--maybe the pushrods are blocked up,only other thing could be a loose cam bearing or other internal 'leak" bleeding the oil pressure off that would normally go to the rockers,or maybe the lifters aren't letting oil go thru--(doubtful if they arent noisy)...maybe someone else has a better idea???... :crazy:
  3. Fierospeeder
    Fierospeeder Banned
    Sep 17, 2001
    315
    Illinois
    if you put new lifters in, do you know how to set zero valve lash?
    Other then that it maybe anything diesel4me or a collapsed lifter
  4. Blazr77400
    Blazr77400 1/2 ton status
    Aug 31, 2001
    652
    Ogden, UTAH
    If the lifters are not adjusted right, it wont squirt the oil out.
    Also, if you are using stock rocker arms, the pushrod may have wore a perfect sphere into the rocker arm and making it so the oil doesnt have a place to go. Try swapping the rocker arms and see if the problem follows those ones.
  5. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    pr just part out the suburban so i can buy those seats!! let me know what your rock bottom price on that burb is mike
  6. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    Well, i took it to a "pro" to look at and he never got it done. Pushrods are clear. I will try some more of this stuff and see what i come up with. Tom, i will talk with my dad and get back to you on the sub.
    thx mike
  7. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Check to make sure distributor does not have to be pointed specific direction. Some v8 chevy's I've heard need the distributor to face a specific direction so the oil galley on the shaft allows oil to the opposite side of the block.
  8. dyeager535
    26,980
    No, you just need a distributor or the housing installed for it to let the oil reach everywhere in the block.
  9. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    I will see what i come up with. thx guys mike
