No oil preasure, Help!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by foxman, Apr 2, 2002.
  1. foxman
    foxman 1/2 ton status
    Oct 22, 2001
    251
    Detroit MI
    the guage reads 0 and the 350 sounds like a deisel on crack. Took the pump off and it looks fine, but the nylon guide was cracked. no excessive wear that I could see. The pump rod turns hen i Wrench the crank over. I took an air hose and blew out the oil cooler, and it flows freely. What elyse could it be?? I'm putting a set of rod bearings in it today while I've got the pan off, what elyse should I do before slaping her together?
  2. A&P
    A&P Registered Member
    Dec 3, 2001
    88
    San Antonio, Texas
    If I were you, just to be safe, I'd replace the Main Bearings too. Just my $.02 Good luck man, doesn't sound good.
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    scary
    you of course checked the dist shaft
