no power, horrible shaking
Discussion in 'The Garage' started by tecton, Dec 17, 2004.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    fouled plugs do this?
    im talking spilt drinks and crying babies at idle
    baaaad shaking
  2. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    certainly sounds like ya might have a cylinder or 2 down.. good place to start, plugs, check wires, cap...
  3. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    pull the plugs and see if there fouled out. we just put a rebuilt 4.9 in a ford over the weekend and it ran fine. then it started shacking real bad. it would idle good for a few seconds then start shacking real bad. had no power whats so ever. we took the truck down to the shop that sells the rebuilt motors and they agreed to look at it. turns out it was a bad pushrod or valve or something. might have even been a bad head gasket cant recall. hopefully in your case its not that serious and the motor just needs a tune up. good luck.
  4. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    That happened to me as well. It turned out one of the plugs ceramic insulators was cracked and arcing to the block and another plug wire was arcing to the dipstick tube. I replaced all the plugs and wires and now it runs great.
