No Power Steering at Idle... better at higher RPMs...BELT IS TIGHT. Help!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dawson444, Dec 31, 2002.
  1. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    Ever since I replaced my header gaskets and the power steering box and went to crossover I don't have much power steering at idle or low RPMs. The belt seems pretty tight. Any ideas? Thanks!
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Either the pump is dying, my case now, or the headers are heating up the fluid so the pump performance drops.
    Are the hydraulic lines anywhere close to the headers or is your engine bay too hot when you open the hood?
  3. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    ....low fluid? /forums/images/graemlins/ignore.gif
    Did you bleed the system out?
  4. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    Heat is not it. Any easy way to test the pump?
  5. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    Fluid is fine, checked it tonight. I put the truck on stands tonight, took and cap off the flid and turned the wheels back and forth and bunch, still the same. I also have been drivig it for a while so I would think it would bleed its self out.
  6. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Well mine is the same, the pump is going out.
    if you tear it down you will most probably find either lots of gum (burnt fluid) or the seals inside are worn.
    I will be rebuilding mine soon, meanwhile I am getting a good workout. /forums/images/graemlins/grin.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  7. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    I agree, that is a pump issue. Replace it and forget it.
  8. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    Alright, I will look into replacing the pump. What are my options? Rebuild the one I have or what? An upgrade would be nice. (AGR is too expensive though) I may go to redneck ram sometime. Any ideas? Thanks!
  9. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Dawson, do you remember my truck? Without the truck moving the steering sucks with the crossover. A hydro assist set up is the cure for my problem and might be the same for you.
  10. dawson444
    Jul 5, 2000
    1,034
    Raleigh, NC
    Its not that it doesn't work when it is sitting sitll, I expect that. It doesn't even work when I am like in parking lots and doing slow turns. Before I went to crossover it was fine.
  11. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I don't think it's the pump. I am leaning toward the steering box or it still has an air pocket in it someplace. If you didn't change the pump then I would look at what was changed first.
  12. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I have to gas my a litle to get it to help out turning, but up in RPM's it works fin...... /forums/images/graemlins/k5.gif
  13. Waxer
    1,857
    Long Beach, CA.
    Crossover requires more power to get the wheels to turn. This has proven itself even on my rig. However, if you recently did a crossover conversion and now are feeling no power at all then you have a weak pump. If rpms give you enough power to turn it, then that only confirms it.
    I would buy a new pump from an auto parts chain and then do some of the mods that WTO has on their technical section of their site to up the pressure a bit. Why? To compensate for the extra power needed to turn with the crossover setup. To prepare for Hydraulic Assist one day.
    I have yet to get a new pump but mine isn't as bad as Dawsons. Also remember that when on the street (pavement) any pump will have to work harder as the tires tend to stick to the concrete, especially wide tires like 14.50 SSR's or 15.50 SX's. When I get on the trail there is enough give in the dirt/gravel that the steering is once again easier to turn.
  14. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Yeah, sounds like the pump to me. Mine was doing the same thing untill I changed it.
  15. Jeremy_C
    Jeremy_C 1/2 ton status
    Mar 26, 2002
    1,381
    East TN
    My truck is doing kind of the same thing, it acts like it has catches in it when you turn the sterring wheel. It will be Smooth(jerk)Smooth(jerk)Smooth(jerk) the whole time ya turn the well. No matter if its cold or hot. Any suggestions? /forums/images/graemlins/ears.gif
    Ya'll should be proud i didn't post a new thread, i just hijacked this one
