no power til 2,500?
Discussion in 'The Garage' started by ilikemud, Jul 5, 2004.
  1. ilikemud
    ilikemud 1/2 ton status
    May 22, 2003
    111
    The Farmhouse, NJ
    just put a new carb on my 78 blazer. motor is a 350 out of an 89 blazer. carb is a 78 rochester q-jet reman. i have no kick down on the 350 trans but even manually shifting i have no power til 2500 rpms, but once u hit that mark you get thrown back into the seat... any help? please!!!
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Does it feel like a bog, or just lazy until that rpm ? Are you running different gears ? Did you change the cam in 89 motor , which was injected ? Depending on gears and weight of the truck it should move itself from a dead stop, but it ISNT going to be like a Camaro by no means . Try a basic tune up , and then start adjusting the carb and timing a little at a time . Usually it just needs a little more fuel for the transition , try the other hole or bending the rod on accelerator pump arm. The other thing , and I don't recommend it if you are green at it , is the APT ( adjustable part throttle ) can be adjusted ( on older non modded carbs , entails removing carb top ) to change how far/fast the rods can go down into the jets /forums/images/graemlins/k5.gif
  3. ilikemud
    May 22, 2003
    111
    The Farmhouse, NJ
    3.73 gears with 36 inch tires, or 31 inch tires no real difference... so i dont think it is a gearing issue. stock 89 cam, was tbi now carburated... just did tune up and high flow oil pump... i dont want it to go like a muscle car, but i want it to get out of its own way... as far as fuel, when it is under 2500 rpms and you floor it, she backfires when the secondaries open, and like i said over 2500 rpms it will throw u back in the seat...
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Backfiring will seem like timing to me . Double check that before adjusting carb /forums/images/graemlins/k5.gif
