no power to fuel pump
Discussion in 'The Garage' started by fright89, Mar 1, 2003.
  1. fright89
    fright89 1/2 ton status
    Sep 27, 2001
    279
    boston
    89 with tbi
    This little problem seemed to come on slowly. First it would not start if I had just shut it off. I would have to let it sit for a few minutes and it would start ok. My fuel pump is a Mallory 4060fi and I can here it when it runs, it is very loud. When it works right it runs for about 10 seconds when you shut off the truck. I think this sucks all the fuel back or something, not sure. This stopped and I think it would flood out a little when I shut it off so it would not start back up if I tried it right away. Then it just died while idling in my driveway, but started fine in a few minuets. Now it just won’t start
    The pump is ok I ran 12v over to it and it came to life with its normal happy whirling sound.
    I have replaced my fuel pump relay and redone some grounds.
    Are there any other modules or relays or stupid stuff like that I could try before I start chancing my wiring harness?
  2. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    check the oil preasure switch if it is bad it shuts off power to the fuel pump. did you check the fuse and how about the wiring
