No Power to ignition?
Discussion in 'The Garage' started by rustyk5, Jan 29, 2004.
  1. rustyk5
    rustyk5 Registered Member
    Aug 3, 2003
    63
    Hampden, ME
    Just swapped in new optima red top battery and all cables to the battery. Fired right up in 10 degree weather and ran great. Parked my blazer about a month ago to start my new floor. I have welded in new cab corners and two patch panels to fix where the drivers seat has cracked the floor. I went out yesterday to warm it up and change the oil and I get nothing. No lights no buzzer nothing. Optima is in great shape and has a charge, all cables are connected cleanly. I even wirebrushed the ground contacts till they were shinny? /forums/images/graemlins/thinking.gif Help! Did I burn something up welding?
    P.S. 85 k5 6.2l/700R with ac,pw,pl and tilt wheel
    Thanks in advance
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Did you check fuses? If thats doesn't do it, you will need to check the fusible links. I am betting on one of these.
    Also, I know it may or may not happen to be true, but I always disconnect my battery when I'm welding on my truck.
    John
  3. rustyk5
    Aug 3, 2003
    63
    Hampden, ME
    Thanks John, I pressed on all the fuses to make sure they were seated properly but it was dark and cold so I left it at that. I guess I'll have to pull each one and look at them.
  4. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Did you disconnect your battery when welding on the truck ?
  5. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    I have always disconnected the Battery cables when welding. You might have popped a fuse, or ignition relay? Do you have lights or other accessories?
    Bill
  6. rustyk5
    Aug 3, 2003
    63
    Hampden, ME
    No I didn't disconnect the battery. Every reference I checked didn't mention it being nessecary. There is nothing wrong with battery, full charge etc. There is no power from the firewall back-I think? I have a friend coming over with a multimeter today so I will find out for sure. Thanks for the input! Andy
  7. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    When your friend with the meter shows up the first thing you need to check is the fuse link on the fire wall.
  8. ctanner
    ctanner Registered Member
    Sep 23, 2003
    7
    I am currently having the same problem. I was thinking an ignition switch failure in my case. It started acting up intermittently so that I originally thought battery or battery charging problem. As with yours my battery is just fine. The strange part is that I am able to turn on most non-ignition switched items like headlights, dome light, horn, radio clock. I am not able to turn on hazard lights, the automatic door locks are not working and there is no power to the power rear window (unfortunately in down position when last able to work!) /forums/images/graemlins/doah.gif. It is strange that these last things don’t work as they are not ignition dependent as far as I remember /forums/images/graemlins/thinking.gif.
    If you get yours solved please post the problem. I will do the same.
    Chuck
  9. camarine
    camarine Registered Member
    May 27, 2002
    78
    NC
    Ran into the same problem a 6 months ago while in California. I wasn't getting any power any where. Turned out to be at the starter. Wires at the starter were all jacked up and a fusible link was screwed up. Re-wired it all and haven't had a problem for about 6 months now.
  10. rustyk5
    Aug 3, 2003
    63
    Hampden, ME
    Well after checking some circuts and fuses that were working just fine, we checked the voltage on the battery. It registered 1.3 volts!! /forums/images/graemlins/blush.gif The battery charger I have has a dial indicator on it and when I attempted to fix this the 1st time the meter showed no power going to the battery, so I thought the battery was fully charged. I don't know if the cold weather or the fact that its a gel cell(optima) has anything to do with the false reading /forums/images/graemlins/doah.gif I checked it after letting it charge a half hour later and the meter on the charger said the battery was charging /forums/images/graemlins/dunno.gif
    Couple hours later it fired right up.
    Boy don't I feel like an idiot /forums/images/graemlins/blush.gif
    I mostly want to that you guys for helping me on the board. /forums/images/graemlins/thumb.gifThis forum is great!! Thanks again.
    Andy
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You might as well throw your Optima away now. They rarely take a charge when discharged.
    They do have a warranty though, so I'd look into it.
  12. gzzgfw
    gzzgfw 1/2 ton status
    Feb 26, 2003
    505
    Why is that, because they are dry cell and start corroding when they are dead?
