NO POWER
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KILLERK5, Oct 26, 2000.
  1. KILLERK5
    KILLERK5 1/2 ton status
    Oct 19, 2000
    108
    Aurora, Colorado
    I HAVE AN 88 WITH TBI, WHEN I HIT THE GAS ALL THE WAY I HAVE NO POWER WHAT SO EVER, THE TRUCK ACTUALLY SLOWS DOWN. I HAVE NO IDEA WHAT THE PROBLEM IS. HAS ANYBODY HAD SIMILAR EXPERIENCES? WHAT NEEDS TO BE DONE TO FIX IT?
    THANKS
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    Is your check engine light on? One of your injectors may be clogged or has died.(just a shot in the dark)
    Have you changed you fuel filter, air filter and PCV valve lately or recently?
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
  3. KILLERK5
    Oct 19, 2000
    108
    Aurora, Colorado
    MY ENGINE LIGHT COMES ON AFTER IVER BEEN ON THE THROTTLE FOR A MINUTE OR TWO. ITS A CODE 44 WHICH IS THE O2 SENSOR IS INDICATING LEAN EXHAUST. I HAVE A NEW AIR FILTER.
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    I am kinda stumped or it is too late in the day! :) Lets see what others have to say!
    Man that sorta ryhmes!! LOL
    I am loosing it!!!!
    Mike [​IMG]
  5. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    Check your fuel filter 1st.
    That '88 should have a fuel pump in the tank, right? disconnect your fuel line from the intake and run a pressure test on it. If it's going out, that'll be the first sign.
    Thomas.
    BTW: TURN THAT CAP'S LOCK OFF ..... please? [​IMG]
    -- '84 K5 Blazer --
    http://stoopalini.coloradok5.com/index.html
  6. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    It's because your caps lock is on[​IMG]..
    hehheee dry eyes
    sounds like no fuel, does it start to sputter after the bog then take off or just bogs tell dead?
    How about hwy cruzin @ 60mph?
    http://www.burt4x4.coloradok5.com
  7. Blaze
    Blaze 1/2 ton status
    Aug 28, 2000
    3,285
    Raleigh, NC
    I think that it is a clogged injector. My S-10 Blazer had the same problem for a while. I took out the injectors and put new filters on them and cleaned them up. It worked fine after that.
    [​IMG]http://www.ncclassics.com
  8. Dieselmh
    Dieselmh 1/2 ton status
    910
    Texas
    I would check the obvious things first, fuel filter, air cleaner etc. It could also be your distributor advance malfunctioning. My fuel pump didn't give me any warning before it croaked, but I guess that could be it also. Good luck.
    Diesel
    If it ain't broke, fix it 'til it is.[​IMG]
