no rear overload, OK?
Discussion in 'The Garage' started by ryaninc, Apr 3, 2007.
  1. ryaninc
    ryaninc Registered Member
    Feb 13, 2005
    45
    Salem, OR
    So on my K5 with 14bolt and 42s, I have stock springs, shackle flip, and no blocks. I want to take out the overload (to be softer) will there be too much axle wrap without a traction bar? thanks in advance. :confused:
  2. BlitzK5
    BlitzK5 1/2 ton status
    Jul 29, 2005
    288
    Sherwood Park, Alberta, Canada
    I did that to but I have yet to get my beast running to test it out yet:)
  3. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    I dont know about removing the overload. I was told just flipping it over is a good idea. I know mine is limiting spring travel more than anything.
  4. YZEATER
    YZEATER 1/2 ton status
    Jan 21, 2005
    2,358
    TARENTUM, PA
    your not going to make it much softer if at all. it is mostly used for limiting travel. look how far your spring has to move before it would hit it. it will help keep the spring from being over worked.
  5. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    If you take it out you might be able to compress the spring more than you can now. With that comes the chance of reversing the spring which wears them out really fast.
    I did not run them on my first set and they were shot after 2 runs. My second set does have overloads but I have only been out once since I put them on.
    If anything the overload will give you close to 1" of lift over without.
    Ira
  6. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I dont have 14 bolts but I have a 4" spring lift with my overload flipped over. It still works to keep the spring from over compressing. I think it gave me a bit more flex with it flipped over. Been runnng it that way for around 2 years now with no problems.
