No reverse lights?
Discussion in 'The Garage' started by lifethroughdeath, Sep 20, 2004.
  1. lifethroughdeath
    lifethroughdeath 1/2 ton status
    Jan 26, 2003
    300
    New Bedford, MA
    Allright guys, swapped in a floor shifter in place of my column shifter, and everything came out fine, except, now I have no reverse lights? And there isn't anything mentioned in those "great" directions. So I'm sure someone else has ran into this problem. How do i fix it? I need reverse lights to pass inspection next week. HELP! Btw its a 700r4.
    Oh and if I just went with some say aftermarket 55 watt back up lights that you see out there, wired into a switch, would that pass as backup lights? Thanks,
  2. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    Centralia, Washington
    I think in Washington the switch idea would work. My friend had a yota (before he rolled it) with a switch leading to his reverse lights. When he was being tailgated (usually on the freeway) he would flip them on-- POOF! No tailgaters! /forums/images/graemlins/whistling.gif
