No snapring on front axle, problem?
Discussion in 'The Garage' started by Geargrinder, Oct 1, 2005.
  1. Geargrinder
    Geargrinder 1/2 ton status
    Jan 21, 2005
    258
    Medford Oregon
    I just switched from auto to man. hubs on an 8lug 10b, and I ran into a problem. I don't have a groove in the stub axle on the end to put the snap ring into :doah: I can't have the snapring & thrust washer behind the hub, it will not seat all the way. I can't put the snap ring on the out side of the hub, theres no recess for it to go into. So the axle is left to free float in the spindle. Is this a bad thing? What problems can this cause :confused: And is there a way to fix it other than swaping out the stub axles?
  2. sweetk30
    Nov 1, 2004
    25,544
    539
    horseheads , ny 14845
    some have grove some dont. it just helps pull stub in to the seal on the back side of spindle better.
  3. Geargrinder
    Jan 21, 2005
    258
    Medford Oregon
    That's what I thought. Will I have a problem with geting water, mud, ect. in the spindle without the snapring?
  4. Geargrinder
    Jan 21, 2005
    258
    Medford Oregon
  5. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    I couldn't get the snap ring back on after going to alloy axles. I will see how well it seals, I suspect it will get more water in there, but my buddy at Randy's R&P says its not that unusual to run without them.
  6. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    the snap ring was needed for OEM spicer lockouts.
