No Sound??? WTF?!?!?!
Discussion in 'Audio' started by Capman2k, Nov 30, 2002.
  1. Capman2k
    Capman2k 3/4 ton status
    Jun 22, 2001
    5,070
    dg
    Welp... I bought me a Kenwood deck yesterday because my stock radio died and I need music...
    SO this morning I took out the stock radio and started connecting wires for the new one, with some help of a few charts that say which wire is which...
    SO... I have power to the deck, but the speakers are inoperable... I've tried just about every configuration I can think of for every speaker and NO sound is coming out... Any ideas on that??
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Run new wires to each speaker.
  3. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Well I'm guessing that the speakers worked with the previous stereo, so the problem is not wiring from the deck to the speakers (short circuits, etc)
    If I had to guess, it sounds like either the wiring isn't connected correctly, or there is some sort of switch on the deck for "mute" or something that toggles between the internal amp and the pre-amp outs???
    It's always hard to diagnose these sorts of things without seeing it....but hopefully those ideas will help a little.
    Good Luck.
  4. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Take a 9 volt battery and your 8 speaker wires (if you have 4 speakers) place one wire on the terminal of the battery and touch the others to it till you here one pop and that is a matching pair, move on to the next wire till you have all of them. Also on lots of kenwoods if one speaker is shorting out or the voice coil is starting to fail the headunit amplifier section will shut down hence NO sound from any speaker.
