No Spark Issue... Needing help!
Discussion in 'The Garage' started by 74BBPowerHouse, Dec 30, 2006.
  1. 74BBPowerHouse
    74BBPowerHouse Registered Member
    Mar 17, 2006
    90
    Mount Angel, OR
    Have a 454. Had it going like a month ago (cause it has a blown tranny) just to hear it rumble and well it ran for 30 seconds and then died. Cranked and cranked. Nothing. Gas in the carb and still nothing. So I went and replaced the cap, rotor and ignition coil. put it on top dead center according to the harmonic balancer. Crank it over and still nothing. So i took out the number 1 plug and grounded it on the header. NO F'n spark! The wire going into the distributor is not getting any juice either. PLEASE HELP!:doah:
  2. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Check your wires. not plug wires but main wires running to your dizzy. If thats not it try seeing if any of your other wires are getting spark. yea sounds dumb but who knows. I just ran into this problem with my 350. But my plugs where bad.
  3. FOR MUD
    FOR MUD 1/2 ton status Premium Member GMOTM Winner
    Apr 6, 2006
    2,801
    387
    Clayton Del
    You gotta have 12volts going into the dist.
  4. n1iic
    n1iic Registered Member
    Nov 27, 2006
    5
    New Hampshire
    Yeah, check fuses in the fuse box. Otherwise, find a wiring schematic and follow it back.
    Did you double check your voltage checking tool on the battery? It's a bitch to follow a problem when the tool doesn't work correctly.:D
  5. FOR MUD
    Apr 6, 2006
    2,801
    387
    Clayton Del
    Or not pushed in all the way.
  6. 74BBPowerHouse
    Mar 17, 2006
    90
    Mount Angel, OR
    i have no juice at the battery wire at the dist. and no spark on the #1. Its not 180* out because the thing ran fine. Just crapped and died on day. The plugs are all off by one on the dist cap when lined up on TDC. The guy who helped with my motor said the dist is one tooth off.
  7. 74BBPowerHouse
    Mar 17, 2006
    90
    Mount Angel, OR
    what fuses could be bad in the block for that? There is not an ignition on if i recall. Just terminals to have power when the ignition is on. im ready to rip out my hair over this. GRRR
  8. FOR MUD
    Apr 6, 2006
    2,801
    387
    Clayton Del
    Won't it be easier to put the dist in the right place so the plug wires would be in the right place? If you don't have 12 volt to the dist, it won't run.
  9. 74BBPowerHouse
    Mar 17, 2006
    90
    Mount Angel, OR
    Sure... but it ran before i dont get it.
  10. FOR MUD
    Apr 6, 2006
    2,801
    387
    Clayton Del
    Try running a jumper wire from the battery to the dist.
  11. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I'm assuming you checked for this with the key in the ON/RUN position? If not then re-check with the key in the ON/RUN position. If you have 12+ then you have either a bad module or a bad pick-up coil. The pick-up coil is different from the ignition coil. The pick-up coil is located inside the distributor and you must pull the distributor and take it all the way apart to change it.
  12. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Make up a jumper wire from the hot side of the battery, to the dist. If it fires and runs right, then start tracing the orig hot wire to the dist. Sounds like you just did some owrk on the engine. Maybe the dist wire got pinched, and shorted out, or got hot and shorted.
  13. BlaKK54Speed
    BlaKK54Speed 1/2 ton status
    Dec 14, 2006
    242
    Omaha, NE
    i would make sure all of your plug wires are ran correctly, that sounds a little funny to me. i have never heard of having plug wires one place off becuase of the distributor being in the wrong place. i would find out why you dont have 12 volts at the distributor wire before trying to replace it with another hot one. make sure its not ground out/blown fuse or anything else wrong with it first. just my 2 cents
  14. 74BBPowerHouse
    Mar 17, 2006
    90
    Mount Angel, OR
    What fuse would control that? Is it hidden in the wiring on the firewall?
  15. 74BBPowerHouse
    Mar 17, 2006
    90
    Mount Angel, OR
    And yes the key was on.
  16. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    I think the power to the inside of the cab, which would then go to the ign switch to the coil, comes from the wires on the battery side of the starter, there is fusible links down there which might be bad.
  17. BlaKK54Speed
    Dec 14, 2006
    242
    Omaha, NE
    there is a fuse in the fuse block (inside cab) labeled IGN check that one. check them all while your at it, they are fairly easy to see once your down there anyway.
  18. BlaKK54Speed
    Dec 14, 2006
    242
    Omaha, NE
    on your firewall there will be a block with 2 posts, random wires branching from both of them, they are all hot power wires. one is connected to the battery all the time, make sure none of them look old/burnt. there will be a jumper wire from one terminal to the other, make sure its still good/conducts electricity.
  19. 74BBPowerHouse
    Mar 17, 2006
    90
    Mount Angel, OR
    There are two fuses on that block where the fire wall is. They look good. Ive looked at the ones on the fuse block itself numerous times.... theyre just all glass fuses
  20. BlaKK54Speed
    Dec 14, 2006
    242
    Omaha, NE
    right you should be able to see if any of them have burnt out elements in them....... the fuses on the firewall may be bad, take a multimeter and make sure they conduct
