No spark on a 88 with TBI. Help!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by great scott, Sep 6, 2003.
  1. great scott
    great scott 1/2 ton status
    Dec 31, 2002
    333
    Utah
    I am helping a freind out with a no start/ no spark problem on a 88 Blazer with TBI and external coil HEI. He has injector paulse, dist rotation, and key on power to the pink wire at the coil, but no spark. We have changed the modgual 3 times, the pick up twice, and ing coil once. With the tach disconected and a test light hooked in place we have key on power, but when I crank the engine over the test light dose not paulse. Any ideas would help.
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Bad coil wire???
  3. great scott
    Dec 31, 2002
    333
    Utah
    good idea but we checked allready and just to be safe we are useing 12 gauge wire tied to the coil tower to test spark. /forums/images/graemlins/1zhelp.gif
  4. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    No spark on a GM vehicle is usually one of two things, either the ignition module or pick-up coil inside the distributor.
  5. great scott
    Dec 31, 2002
    333
    Utah
    I agree thats why we have changed them both at least twice thinking we must have gotten bad parts.
  6. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Do you have spark at the coil? If you have spark at the coil but not the plug wires then I would suspect a burnt through rotor allowing it to ground out.
  7. great scott
    Dec 31, 2002
    333
    Utah
    nop we have no spark at the coil.
  8. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    No spark at the coil and since you have already replaced the coil I would say ignition switch is next.
  9. great scott
    Dec 31, 2002
    333
    Utah
    I have power coming from the ing switch on the pink wire on the coil, so I belive the ing switch to be good.
