no start......fuel problem...PLEASE HELP!!!!!
Discussion in 'The Garage' started by bigbadchev84, Dec 14, 2005.
  1. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    on one of my trucks it is has a starting issue, it has a edelbrock carb on it with a brand new napa metal fuel filter. well after it gets cold it dosent wanna start without starting fluid or dumping gas down the carb, its not the choke because it is a manual choke and i am familiar with how to work one. when it is completely cold i can look down into it and pump the throttle and it wont spray any gas, it has great spark and once i get it started it runs great and fires up everytime, just have the no start when its been sitting for a while, i have just replaced the fuel pump also thinking it might be bad but to no avail. i did notice the other night the the letters on the fuel filter are upside down going into the carb, but there is not a direction arrow, is it somehow loosing its prime? please try and send me in the right direction here! thanks
  2. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    IIRC the accelerator pump should store gas in it so that when you pump initially, it squirts the gas in to start. Sounds like the fuel is bleeding off somewhere.
  3. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    anyone else have any ideas?
  4. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    If you are not seeing gas squirting when working the throttle, then I would replace the accel pump, but 1st check to make sure it is hooked up.
  5. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    You would have to be losing gas from the float bowl or have a bad diaphram for the accelerator pump not to work.
  6. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    I had this exact same problem, I changed everything you did even rebuilt the carb. Turned out it was something in the gas tank. I put a fuel cell in my rig and never had the problem again. I never inspected the tank to see what was wrong, just upgraded to a cell because I wanted to and have never had a problem since then. I would suggest dropping your tank and cleaning it out. You might have something in there that floats to the bottom near the pick up after it sits, the fuel pump is not strong enough to draw fuel, but when the engine is fired with some gas down the carb it kicks the fuel pump a lot faster allowing it draw enough fuel to bypass the foreign object.
  7. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
  8. BadBob
    BadBob 1/2 ton status
    Aug 14, 2005
    158
    Lyndon, KS
    I'm still having the exact same problem. Even with a brand new QJ, so the tank seems to be the place to look.
  9. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    ok well here is the deal......i was driving home from a friends house on the freeway, and it started to buck and stall just like it always does when the tank is ran dry, so i switch tanks and it keeps doing the exact same thing then it starts to backfire through the carb, i had installed a new cam in the motor a couple thousand miles back and was having problems building oil pressure -the parts guy gave me the wrong lifters, so i didnt break the cam in properly, while i was trying to diagnose the problem i replaced the fuel pump and fuel filter and i cant remember for sure but i think i swapped carbs too, then decieded it was a bad cam, i pulled the motor and dissasembled and sure enough i had 1 flat lobe and 2 really rough pitted lobes, so i swapped out the cam and re-installled, now i am running into this problem, i never had a problem at all before coming home from my friends, it was always a pump the pedal twice and she would fire and run smooth. so i am kinda stumped as to what the problem is, i dont think it is in the tank, because i have the problem on both tanks.
  10. mouse
    Nov 10, 2003
    1,448
    Great Falls Mt
    Have you looked at the fuel pump?
  11. 3 on the tree
    Oct 16, 2004
    3,970
    gunnison colorado
    Put a pressure gauge on your fuel pump outlet to verify operation. Is your fuel evap system still hooked up? I have seen the charcoal canisters clog up and cause a vacuum when the fuel pump is trying to draw fuel. Easy way to check for this is remove gas cap and crank it up. If it fires up and rund right, then you have a blockage somewhere in the evap system.
    Another thing to try is bypassing the tank switching valve, to see if it is sticking , causing fuel starvation.
  12. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    i checked the fuel pressure and it is 6lbs while cranking it, i believe that is about right.....i have no emissions on my motor at all, i cleaned everything up and kept only what was neccesary for it to run.
  13. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
  14. gauder
    gauder Banned
    Aug 26, 2005
    1,613
    done
    6 to 8lbs for a carbed motor, so you're in the range their.
  15. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    ok guys i replaced the accelerator pump in it and to no avail. i just ended up swapping out carbs, the old one was completely full of gas but wouldnt squirt gas out of the 2 nozzles, the substituted carb works almost perfect, i gotta adjust the choke........but what would cause this? it runs fine when warm, i just gotta dump gas or starting fluid to start it.
  16. gauder
    gauder Banned
    Aug 26, 2005
    1,613
    done
    Ever have any backfires through it before?
  17. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    yes a few why? its doing it when its cold on the new carb too now, only when you hammer down on it though
  18. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    It's gotta be something in your fuel tank.....
  19. RustyParts
    RustyParts 1/2 ton status
    May 26, 2005
    235
    Wyman, Kentucky
    Sounds like the passageway from the accel pump to the squirt nozzles were plugged. Ya'll got mud dobbers in that part of the country?:D
  20. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    fuel tank is ruled out, i swapped carbs and it is almost fine now, just a matter of tuning and adjusting choke, i guess a piece of crud is in there, but why does it work fine after i initially get it running and warmed up?
