No Start, No Spark, urgent help please...
Discussion in 'The Garage' started by K5er4Life, Jan 28, 2007.
  1. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    I am having trouble finding out what exactly is my problem as to why I am not getting any spark. Its a 87 TBI. I am getting power to the power wire on the external coil but am getting nothing out of the coil. I figured the coil was the problem so I replaced it. Now Im starting to think it might be a relay, fuse or something. But I dont know where to start. These damn electrical problems suck. Please help need it urgently as my truck needs to move no later than tomorrow.
  2. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    check the ignition module, it is under the dist. cap, most auto parts places will test it.
  3. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    check the modual under the cap and the pickup coil under the cap, theses are the biggest causes for a no spark situation
  4. K5er4Life
    Oct 16, 2002
    1,456
    Bellflower, Ca
    Thank you, I will run out and try that, but I am a little unclear as to how to go about removing it. I know its under the cap and under the rotor, hell Ill check back in a few minutes once I see what everything looks like under there. Thanks for the help, be back in a few...
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Remove cap and rotor, then unplug the two wiring connectors and remove the two screws that hold the module in place. Install new module. Be CERTAIN that you smear the back of the new module with the thermal grease that comes with it,before you install it. Otherwise it will overheat and burn out pretty quickly. :(
  6. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    If the module doesn't fix it then you need to replace the pick-up coil inside the distributor but you have to remove the distributor and take it completely apart in order to change it.
  7. K5er4Life
    Oct 16, 2002
    1,456
    Bellflower, Ca
    Thanks guys, I really appreciate it, got it all straightened out. Turned out to be the pickup module. A quick look at the chiltons helped a bit too. Last night I was on my way back home when the truck took a dump on the freeway. Luckily I wasnt far from home and had a new bottle of jack so when I waited for AAA to show up I had some drinking to do.:saweet:
