No Start
Discussion in '1982-Present GM Diesel' started by ae864cd, Nov 11, 2001.
  1. ae864cd
    ae864cd Registered Member
    Sep 26, 2001
    22
    Orange County California
    Hi Everyone, just finished a rebuild on my 6.2 after installing the engine and all wires checked. I noticed that the glow plugs are not cycling and the glow plug light does not go on. also i know that you have to bleed the air, but what is the correct procedure, i don't want to kill my pump. any advice will help,
    thanks
  2. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    I dont know about the correct procedure for bleeding the fuel system, but I always losen an injector line and crank the engine over until fuel comes out. And it shouldnt hurt your injector pump cranking it, because it has a mechanical pump feeding it.
    1984 GMC Jimmy 379 diesel, 700R4, 3.73s, 31x10.50 x 15
  3. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Fill out your bio ae so we know what yr we're taking about. Assuming the filter has been bled (or not changed yet) loosen the injecotr lines at the injectors, have some one spin the motor over while you tighten down the lines that have realy started do leak. After a couple of cranks (don't smoke the starter) you should be good.
    Do you have the controller module mounted on the manifold? Is it getting power?
    Real trucks don't have spark plugs!
  4. Danno
    Danno 1/2 ton status
    Aug 4, 2001
    487
    Rockford, IL
    I've got the procedure at home in my Haynes manual. It worked great when I bled the system incorrectly after a fuel filter change. I'll post it first thing when I get home, unless someone else posts it before me.
    1984 K5 Blazer 4x4 Silverado
    6.2L diesel, 700R4, 3.42 gears, 31x10.5" tires
  5. ae864cd
    Sep 26, 2001
    22
    thanks guys got it running finally
  6. Danno
    Aug 4, 2001
    487
    Rockford, IL
    Crap... I just realized I never got those instructions to ya'. Glad to hear you got it running!
