NO TAIL LIGHTS
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DOUGHBOY, Nov 24, 2000.
  1. DOUGHBOY
    DOUGHBOY Registered Member
    Oct 8, 2000
    68
    central illinois
    on the way home tonite i relized i have no tail lights.everything else works fine.turn signals,brake,dash,headlights etc..but no tail lights.i thought my dash lights are on the same fuse so i was thinkin it wasnt a fuse,and i dont see both bulbs burning out at the same time.any ideas
    guns dont kill postal workers do.
    CENTRAL ILLINOIS
  2. tRustyK5
    Jul 23, 2000
    36,182
    1,388
    E-town baby!
    I know it sounds dumb but check the bulbs first. Maybe one has been burned out for a while and now the other one went too. Do the front parking lights work?
    Rene
  3. Storm Trooper
    Nov 24, 2000
    4,640
    Got a meter or a working bulb and a couple of wires? It sounds like you have a loose or broken wire going back to the lights. You can check this by pulling a bulb, turn the lights on and see if you have power. If not, work your way back. Good luck....
  4. Blazerbob
    Blazerbob 1/2 ton status
    214
    Western NY
    I have seen blazers that had holes rotted in the floor and the rough metal broke through the wiring.Follow the wires from the back to the cab and check for breakage or bare spots shorting out.
    <font color=blue>Blazerbob</font color=blue>[​IMG]
  5. DOUGHBOY
    Oct 8, 2000
    68
    central illinois
    i have checked the wires and bulbs.everythings fine.i was thinking could a bad headlight switch have anything to to with tail lights,cause i have brakelights and headlights just thinkin that could be it,maybe
    CENTRAL ILLINOIS
  6. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    This summer one of my trailer hookup wires was worn thru and it wreaked havoc on my taillights. I found it rubbing on the hitch.
    creepin' and crawlin'
    Jim
  7. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    On '81-'87 the brown wire that runs to the front and rear powers the side marker lights, parking lights(tail lights), and tag light. If your front parking lights are working, then its in the wiring from the bulkhead in the engine compartment to the rear of the K5. I had troubles with mine due to some previous owner using the crimp on type wire connectors for a trailer. Of course they cut a few wires and leave a hole in the insulation. The wire corroded and finally broke in two. It was a mess.
    Cruisin in my '73.
  8. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    I had the same problem and it was driving me crazy. I found out, (after a while), that the tailgate was closing on the wires and that the wire was actually cut from inside the rubber insulation...................js
  9. DOUGHBOY
    Oct 8, 2000
    68
    central illinois
    goose you were on the money with that one.someone had spliced wires for trailor lights and the brown wire was coroded and it broke in to,but it took me awhile to find it.with the reese hitch in the way i couldnt get to the wires inside the frame rail next to the gas tank.well that where she was thanks everyone for the help.
    CENTRAL ILLINOIS
  10. Goose
    1,127
    Glad I could help.
    Fencepost eater
